90K mi Maintenance
Old Jan 26, 2007 | 10:56 AM
8T9GTA's Avatar
Default 90K mi Maintenance
Hey everyone,
My 1996 960 sedan recently broke 90k miles so in the next week or so I'd like to perform the recomended maintenance to the car. From what I've read the main things to be done (besides oil change, inspecting brakes, fluids, etc) is replacing the air filter and spark plugs. My question is regarding the spark plugs. I've never changed them before and am wondering if it is difficult and if there is anything special I should know before changing them. Also, should the spark plug wires be changed as well and are there any particular brands/types of spark plugs you would recomend. Thanks for your help.
Old Jan 26, 2007 | 08:56 PM
Default RE: 90K mi Maintenance
The plugs aren't that bad. You have to remove the top engine cover.
Then the coil packs to get to the plugs.
BTW if you didn't get it above your car has coil packs 1 per cylinder.
No cap,rotor,or wires.
Old Jan 31, 2007 | 10:36 AM
8T9GTA's Avatar
Thanks for the info. I'll probably be changing them this weekend. Any recomendation on brand of plugs, or are they all pretty much the same?
Old Jan 31, 2007 | 08:42 PM
Bosch are pretty good.
Old Feb 4, 2007 | 02:12 PM
8T9GTA's Avatar
I replaced the plugs yesterday and it was pretty simple just like you said. Thanks for your help.
Old Feb 4, 2007 | 05:46 PM
You welcome does it run better?
Old Feb 5, 2007 | 09:23 AM
8T9GTA's Avatar
Yeah. Itran fine beforeI changed them, but it does seem to run even better now. The plugs I pulled out had barely any center electode left and they said Volvo on them. So I have no idea how long they've been in there for.
Old Mar 21, 2007 | 11:06 PM
volvolove's Avatar
Have you done transmission flush? If you haven't, the color of the fluid will look dark black.
teaberry
Jun 10, 2014 04:14 PM
Steff925
Mar 26, 2009 06:33 PM
jbnery6465
May 22, 2008 05:23 PM
tenchu
Mar 12, 2008 08:00 PM
fordbad
Nov 19, 2007 12:31 AM
