'94 960 engine knocks when hot...more details inside >>
I have a 94 960 with 226,000 miles.
The engine knocks really bad when it is hot.
What it does:
Doesn't knock and runs like a top when it is cold.
When the engine warms up (after a 10 or 20 mile highway drive) and I come to a stop I can hear excessive knocking in the motor. It is also be drinking coolant.
What I have done so far:
As a precautionary measure I filled up with high quality non ethanol fuel and put in a bottle of high mileage fuel system treatment hoping it would go away. It didn't.
I feel this is a mechanical issue since it only happens when the motor is hot. Are there electrical issues to also look into ?
What I plan to do:
Pull the spark plugs and make sure they look good (there were changed about 10k ago). Inspect in and around spark plugs and coil caps....
Head Gasket ? - no apparent condensation on tail pipe. Exhaust smells normal.
What do I need to do next ?
What it does:
What I plan to do:
