Originally Posted by volvoofsocal
(Post 287646)
I looked at the diagram. So if I'm reading it correctly, parts 7 through 14 are for the PCV, including the flametrap which is part no. 12. Is that correct?
http://www.fcpgroton.com/images/prod...asevent960.jpg Be very careful with # 4a and 4b -- if you push them, they may fall into the oil pan, which means you need to open the pan, for which you need to remove the subframe. If you decide to clean them, you can take # 1 thru 14 (except # 4a and # 4b) leave them in a kerosene container overnight and clean them with wires, whatever, so the crude comes off. How to get to them -- two options: 1- Remove accessory belt, remove Power steering pump, move alternator, remove throttle cable and body. 2- Remove the intake bowl. If you go this route make sure you get a new intake gasket (about $ 6), and know about the hidden bolt at the bottom of the bowl. Brickboard recommends Option 1. Having done both, I prefer option 2. |
Thank you for the information but I think we'll have to take it in. We've been trying to take off the flametrap to clean it up but we're having hard time doing that.
I was wondering if there are any alternatives to servicing the PCV and the flametrap, like switching to synsthetic oil or using a product that cleans the engine including the PCV and the flametrap. Do you think that would work? Thanks. |
That color photo of the Flame Trap & EGR is a photo that I posted the other day. You can remove those funny clamps with a small tip screw driver. I usually just get the tip of the screw driver under the tip of it and pry up. Or, like Henry said, simply clip it with tin snips or wire cutters. The neat thing about those clamps is the fact that they are very narrow/thin. Other clamps, like the one I installed is wider.
If the PCV system is plugged, it will usually toss a cel code. If there is oil coming from it, either the system is clogged or the flame trap screen is clogged. That being clogged can cause other oil leaks, some bad & expensive to repair. Get that serviced ASAP. The part that is circled in the picture #14 is the flam trap assembly. The part comes apart and you can clean or replace the screen in less than 30 minutes. You will need to clamp it back together when you take it apart. |
(Post 287693)
(Post 287693)
After cleaning/replacing the PCV components, yes, synthetic oil helps in keeping it clean, but it won't dislodge the baked-in gunk. |
Thank you very much.
Just to make sure I understood you correctly, regarding the flametrap: it is attached to the PCV part no. 1 by hose no. 7 and clamp no. 8 and clamped to the air intake by clamp no. 14. To take it out I need to remove both clamps after spraying them with WD40, then twist the plastic piece no. 10 to open it up and clean it and clean or replace its components no. 11 12 & 13. Is that correct? Sorry for the novice questions. Thanks. |
The flame trap unit is #9 - #12. You twist #12 off of #9. #10 is the actual flame trap screen that can be cleaned or replaced. #10 cost about $1.50.
(Post 287711)
Thank you.
We were able to finally take the flame trap apart and found out that is not plugged and the leak was due to the rubber ring no. 10. The rubber ring was hardened and turned into plastic and was not sealing properly. We changed it with a new ring and the leak is now history.
Thank you all very much |
Unfortunatly, the fumes did not go away, but we found out that a coolant hose going into the fire wall, maybe for the heater, has a very slow leak. This hose is right next to the vents by the windshield.
Could the coolant leak be causing fumes that is making me sick coming through the vents inside the car? We'll replace this hose anyway. We did not notice any significant loss of coolant from the reservoir so we hope this is a good sign. Your thoughts please. |
(Post 288834)
Have you serviced the cooling system? |
My mechanic looked at the car in general for safety when he replace the timing belt and water pump and never mentioned the coolant leak. It is so small that you one can miss it easily. I saw it and smelled the coolant through the air vent inside the car.
It is a problem here in California finding a good reasonable mechanic. They are are all very expensive. I'll take it in again. |
