'95 960 oil pooling around coil
Old 06-04-2014, 03:40 PM
southpaw47's Avatar
Default '95 960 oil pooling around coil
Just found the cause of the #3 cylinder misfire. Oil pooling and seeping down to spark plug. Cleaned the coil and plug and it fires 100 %. I am of the thought that the oil filler cap gasket might be worn and is the reason the oil is accumulating. Does this sound possible/plausible?
Old 06-09-2014, 03:30 PM
danr960's Avatar
Yes, the oil filler gasket would be my first suspect. If the head has not been tampered with in a repair that is, other wise the o ring at the bottom of the hole is shot and is seeping. But usually it is the filler gasket.
DanR
Old 06-09-2014, 04:13 PM
southpaw47's Avatar
DanR
I suspect that. Thanks Dan. Now I need to find one.
RGHamilton57
06-29-2015 08:22 PM
Ricardito
08-14-2012 08:29 PM
ciao-rich
06-13-2008 05:01 PM
Quick Reply: '95 960 oil pooling around coil
