carld6859
Old Jun 11, 2011 | 04:35 PM
carld6859's Avatar
Default carld6859
I have a nightmare 95 960 wity 95000 miles on it and has 7 codes-112,123,232,212,223 and 444,Where do I start? I am assuming that the computer is at fault because I replaced o2 sensor and t.p.s.
Old Jun 11, 2011 | 05:16 PM
dan550i's Avatar
I would not assume that yet. Are you sure the throttle sensor is the correct one? The correct 02 sensor? Where did you buy them, do you have the old ones still? You could try replacing one and see if anything changes.
Does the throttle fully close as it should when idling? Are there any other unplugged sensors?
Is it running at all, why did you replace the 02 sensor and throttle sensor?
Did you try to erase the codes? Are the cruise control and throttle cables in their normal positions?
95,000 miles, still new.
DanR '94 964 356,000 miles (122,000 on the new engine)
Old Jun 12, 2011 | 09:26 AM
carld6859's Avatar
I replaced yhe o2 sensor with a 4 wire sensor like the old one that was in there because of a code retrieved. The tps looked exactly like the old one,both parts from advance auto parts.I bought the car last winter and it did not run well at lower rpms it didnt really run well at all drove the car 250 miles at 75-80 mph in a blizzard.The car has always been hard to start,yesterday it died and will not restart sounds like it is not getting any fire,gave it a shot of propane still did not fire.Have also replaced 3 coils because the old ones were shorting out.Also replaced idle control motor because it would keep running (humming)after the engine was shut off. Is there any adjustment to the t.p.s.? I don't think any sensors are unpluged unless yhey are on the back of the engine there is a loose 2 wire plugin on the rear of the head.There is also a vacume line near the master cyl. I cannot find a home for it has a screw in it to keep vacume from leaking. The cruise control also does not work. thanks
