Code P1617 on '96 960 Volvo
Old Sep 27, 2011 | 07:43 PM
J Brad's Avatar
Default Code P1617 on '96 960 Volvo
Anyone ever deal with a P1617 code on a '96 960 wagon. Wife shut it down, came out & cranks over OK & everything else appears to be OK. Fuses OK, getting ready to check all power wiring & relays. Like an idoit, I cleared the code before writing down the description of the code.
Thanks, Brad
Old Sep 27, 2011 | 09:19 PM
Henry10's Avatar
It's always adviseable to erase the code when it first appears. If code persists, then troubleshooting should begin. Anyways, code description is:
"P1617 Cable fault between AW 30-40 TCM and Motronic 4.4 ECM (lamp lights)"
It looks like the first signs of ignition switch failure. Ease and cheap to replace when times comes.
Old Sep 27, 2011 | 11:12 PM
J Brad's Avatar
Thanks,
Found some info on another site earlier after searching, pointing in the direction of the trans connectors & grounds. Going over various connectors, found the 3 connectors on the side of the trans, the front one was badly corroded due to the heater flow control valve leaking, directly onto it. Re-did connector, still no start.
I'll look into the ignition switch.
Thanks for the input, Brad S.
Old Sep 28, 2011 | 10:30 PM
J Brad's Avatar
Ignition switch tomorrow. Checked all the relays. I did find that the fuel system relay is bad. Its' coil shorted out. A friend is coming by tomorrow that has alot more experience with late model cars.
Brad S.
Old Oct 6, 2011 | 12:32 AM
J Brad's Avatar
Well Henry10, you nailed the P1617 code with the ignition switch failure. I found a rear-ended '96 960 sedan in the junkyard, got the ignition switch, the charcoal driver side sun visor & RT front side marker light also, all for $17.25 (half off day). Now I just need to find a LT rear taillight lens.
The fuel system relay was also bad & fuel pump died. I'm still not understanding all of it, but the 960 runs great again.
If anyone tries to be cheap on a replacement fuel pump (I was as $ is non-existent at the moment), don't get the Airtex E8186. It's smaller in diameter & nothing was listed about a retro-fit kit. I ended up getting one from Napa (Bosch)
Old Oct 15, 2011 | 02:13 AM
J Brad's Avatar
The 960's still running great. I did mess up the sending unit though while replacing the fuel pump (fuel gauge stuck at 1/8 tank). A project for another day.
Old Nov 14, 2011 | 02:57 PM
dg210's Avatar
I get the same code P1617. There is a electrical problem. If i plug in the a/c compressor fuse the starter will not shut off. Replaced the ignition switch and still doing the same thing. Put a toggle switch so i can use the a/c but does anyone have a direction to point me in?
Old Nov 14, 2011 | 03:34 PM
Henry10's Avatar
Originally Posted by dg210
If i plug in the a/c compressor fuse...
Which fuse number (and Amp) is that?
Old Nov 16, 2011 | 10:17 PM
dg210's Avatar
It is fuse #5 under the hood and it is a 10A labeled AC-relay emiss. syst relais ac syst emiss. If i remove the fuse the starter does not stay running. The fuse will blow if i keep it in but when i use the toggle switch for the starter I can use the AC. Just not sure what direction to go right now.
clutch33
Aug 17, 2014 03:45 PM
LOVEvolvos
Jan 20, 2013 09:02 PM
LOVEvolvos
Apr 23, 2011 03:52 PM
Elsid
Sep 9, 2010 08:42 AM
gzh
Mar 21, 2007 09:29 PM
