Engine Knocks... What could it be?
Old Aug 8, 2010 | 02:47 PM
Big John's Avatar
Default Engine Knocks... What could it be?
My engine starts fine, but when given gas, the engine starts to knock and the whole car shakes. What could it be? Please help!
96 Volvo 960
213,000 miles
Old Aug 8, 2010 | 09:15 PM
Do you have a CEL? If so, have you pulled codes?
Old Aug 10, 2010 | 10:42 AM
kendogg's Avatar
What kind of a knock?? Metallic rod knock sound, or sound from the entire engine moving? Check your motor mounts, and check your oil. If you have an oil pressure gauge, check your oil pressure as well.
Old Aug 15, 2010 | 03:06 PM
zmontgomery's Avatar
While the car is running unplug your mass air flow sensor. It's on the intake hose right after the air filter box. If the engine smooths out, you've found your problem.
azastrow1987
Jan 15, 2014 10:03 PM
omniahobo
May 8, 2010 12:24 AM
frank_haren
Sep 26, 2009 06:01 PM
JC
Oct 8, 2005 03:43 PM
skamil
May 25, 2005 06:54 PM
