foglight replacement
pls.help me....trying to change hallogens for front foglamps...they still dont work.each hallogen come with an electric wire and a fit-in pin .after checking relay box and fuse box they still dont work.do i have to insert the hallogens in side socket and clip them to have continuous current or just the fit-in pin should light them?
RE: foglight replacement
They ground between the bulb and the housing.
Do you have power at the light assembly? |
i had to fit them in the socket and strap-lock them for them to ground...everything ok now...ty...im super happy...nothing wrong with the car...its a beauty
ORIGINAL: brasron pls.help me....trying to change hallogens for front foglamps...they still dont work.each hallogen come with an electric wire and a fit-in pin .after checking relay box and fuse box they still dont work.do i have to insert the hallogens in side socket and clip them to have continuous current or just the fit-in pin should light them? Butafter I clipped the bulb into the place and closed the cap, it was working fine. |
