foglight replacement
Old Feb 13, 2007 | 06:46 PM
brasron's Avatar
Default foglight replacement
pls.help me....trying to change hallogens for front foglamps...they still dont work.each hallogen come with an electric wire and a fit-in pin .after checking relay box and fuse box they still dont work.do i have to insert the hallogens in side socket and clip them to have continuous current or just the fit-in pin should light them?
Old Feb 17, 2007 | 01:11 AM
Default RE: foglight replacement
They ground between the bulb and the housing.
Do you have power at the light assembly?
Old Feb 18, 2007 | 12:15 AM
brasron's Avatar
i had to fit them in the socket and strap-lock them for them to ground...everything ok now...ty...im super happy...nothing wrong with the car...its a beauty
Old Mar 21, 2007 | 11:00 PM
volvolove's Avatar
ORIGINAL: brasron
My right side fog light wasn't working.I opened the cap, and there was water pouring out. I got a new bulb from advanceautoparts and I replaced them, I wanted to check if they were working before putting all the wires in. It wasn't working so I was thinking "I guess something is wrong"
Butafter I clipped the bulb into the place and closed the cap, it was working fine.
DKaz
Feb 3, 2008 12:52 AM
monEmakindave
Feb 1, 2008 06:43 PM
fritzlovesmary
Jul 26, 2007 10:37 AM
gfreeman9mm
Apr 23, 2007 04:21 AM
jc740T
Nov 29, 2004 02:11 AM
