Newbie needs B230FT Engine
Old Aug 29, 2005 | 11:31 AM
Gogats's Avatar
Default Newbie needs B230FT Engine
Hello, Great web site! This is my first Volvo, but I have worked on both my neighbors 740/760 for a few years now. I always admired them and found a deal I couldn't pass on.
I just bought an immaculate '86 760 Turbo Wagon with 149K. The first owner shows all dealer maintance until 146K. Second owner seized the engine at 149K. I have access to a low mileage B230F(non turbo) engine. This car is too nice to jerk around with the wrong engine, but could I use the non turbo engine with the turbo and accessories? What are the differences between them?
Assuming the B230F is not acceptable as a replacement. What are my options for a used engine? I understand the B230FT was used up till 95 in the 940 and that the 93-95 were stronger assemblies. Are they interchangable with the 86 accessories?
Any help would be great. This car looks like a 3 or 4 year old car! It must have been garaged. Head liner is still perfect, leather is not cracked! I wan't to make the engine 100% again and drive it.
Thanks
Jake
Old Aug 29, 2005 | 08:28 PM
Default RE: Newbie needs B230FT Engine
I would swap the turbo head onto the nonturbo engine and drop it in. But thats just me.
Then you can look for the proper motor with low milage.
Old Aug 30, 2005 | 04:56 PM
Gogats's Avatar
I found a 92 940 Turbo sedan with 120K that I can get for $500. I was thinking of swapping the engine trans and trans as one unit, but I am thinking of taking your advice and swapping the turbo head to the 90 N/A motor. I mean I already own it and would only need the headset gaskets and a return line for the oil to the turbo. My concern is the condition of the turbo head. The best I can tell is the last owner lost the coolant (maybe head gasket failure) and over heated it till it seized. So the turbo head maybe damaged. I guess I will need to pull it to be sure. Are there part that should be changed noe when I have the engine out, like the t-belt, tensioner, water pump, etc?
Old Aug 30, 2005 | 10:02 PM
I would change the belts and waterpump,thermostat and stuff like that to be safe.
I just remembered something make sure the N/A block has a removable plug for the turbo return line.
AnEskimo
Jun 8, 2013 09:12 AM
DIAZ1981
Jan 5, 2011 06:41 PM
firebird28
Feb 22, 2008 05:20 AM
1990TURBO740
Dec 16, 2007 07:24 PM
jesselou
Apr 22, 2005 06:42 PM
