oil plug problems
oil plug problems
HI I bought the 1998 v90 and I love it the pep ,the gas mileage , the handleing , I was ready to change the springs ,sway bars ,brakes BUT after useing the car I am sastifed and I do not have to do any of this to the car.My problem now is I went to change the oil and I think that the Jolly green gaint at the quick change oil station thigthen the drain plug !!!!Needless to say the corners are rounding off, even after using a 6 pointbox wrench.so I stop ped because if I did get it out I would not bend able to reuse it . I will pick up a new one and try again .I have a wrench that thighens the more pressure you put on it. My last resort is to drill it and use a easy out . My question is are there any other tricks that I could use ? and or should I have this done at a gargage. Thanks for any input.
RE: oil plug problems
To save you alot or trouble and cursing take it to the dealer and let them do their oil change special for like $20.00 and they will ask you to replace the drain plug as well.Some people never install the aluminum crush washer and just tighten it down and then it is a bear to get off.
Thank you for the input for the oil plug problem . I will take the car to volvo . I would be working on her roughly 30 miles from the closest dealer, so if I did run into trouble it would just add to it. Just a quick question how do you get a picture on this site?? Or maybe I should ask seeing how you like 5.0 mustangs would you be interted in seeing my toy which uses the 5.0 drie train. John
Yes I would like to see your toy!!!!!
When you click reply not quick reply then on the bottom of the screen there is the word file then to teh right of it click here to upload.Then upload the pics.Also make sure you click on the box to embed picture in post then is should work.
This is my car.
[IMG]local://upfiles/853/AF24579066AA492789518DB33C682BC9.jpg[/IMG]
[IMG]local://upfiles/853/A370ADDFB4F24E67BF195C1DFA91DAE6.jpg[/IMG]
[IMG]local://upfiles/853/AAD85B98A1C14AF0B18F4DC93A066595.jpg[/IMG]
This is my car.
