power windows
RE: power windows squealing sound
Me too- ('97 960) I tried WD40 around the rubber seal (inside and outside) but I guess the sound is coming from the internal levers in the door panels that expand and contract to raise and lower the window... Anyway, I hope I'm not continuing to damage anything inside. Has anyone run into this problem? Thanks...
When i had a 93 960 the clutch had burned up in the power window so the window would make a horrid noise when it got to the top or bottom of it's run. It ended up burning off the top few teeth and i replace the motor and gear assembly with 1 from a junk yard which wasn't that hard.
mrbaja
12-17-2005 03:41 AM
