Rallying a 85 turbo 760 need help
Old Sep 19, 2005 | 03:46 PM
BlacknRedGT's Avatar
Default Rallying a 85 turbo 760 need help
ok two questions... how could I raise the suspension up w/o spending alot of money and also...
could I ghetto rig the turbo system to up the boost a couple of psi with the engine handling it???
I have no clue what the engines bottom end can handle.
Old Sep 20, 2005 | 01:26 AM
Default RE: Rallying a 85 turbo 760 need help
Open the waste gate more to get a little more boost. If you go to far you will know you will loose power in boost if you go to far.
Try getting coil spring expanders and see how much higher it will be.
Old Sep 20, 2005 | 02:41 AM
thanks for the reply.. also how much boost can the stock engine handle?? I also took the air filter box out and ran straight air and Im getting turbo surge... would this be fixed with a aftermarket air filter.. or should I leave the stock box???
This engine has 250,000 miles on it so I doubt the compression is good but I have yet to check it.
Old Sep 20, 2005 | 08:47 PM
Put a K&N filter or similiar on it.
I think it is around 12Psi is max.
10 will be fine.
A buddy of mine was running 10 with Nos and it was fine.
CVO
Apr 14, 2010 10:29 PM
bunky3301
Mar 25, 2008 06:38 PM
volvoyoungster
Jan 3, 2007 08:52 PM
batac_boy
Dec 28, 2006 11:29 AM
Grog
Aug 10, 2006 11:22 PM
