s90 transmission mount
Old Feb 20, 2006 | 07:14 PM
pettersolberg's Avatar
Default s90 transmission mount
Are there any tech articles, or does anyone know what is needed to replace a 1997 s90 transmission mount.
thanks
Old Feb 20, 2006 | 09:10 PM
Default RE: s90 transmission mount
It is not that hard. Support the tran. Remove the transmission crossmember. Then replace the mount.
You will need a 14mm socket,12mm socket and a 15mm socket Also a 10mm socket to remove the screws for the o2 sensor wiring.
Old Sep 22, 2019 | 05:36 PM
AfonsoF1999's Avatar
Reviving a really old tread but does anyone have torque specs for the trasmission mount nut and the crossmember bolts?
Old Sep 22, 2019 | 09:39 PM
dunno about the S90 but my guess it should be the same as the 850 which is 37 ft-lbs for the transmission mount bolts and 77 ft lbs for the frame bolts
Volvo 850 automatic transmission removal & installing instructions
AfonsoF1999
Sep 22, 2019 09:40 PM
toaoemerald
Jan 24, 2012 11:24 PM
schmuecker
Aug 21, 2011 02:29 PM
duck4volvo
Oct 1, 2010 01:37 AM
halcyon419
Mar 24, 2009 11:17 PM
