Trouble with oil line on radiator
Old Oct 19, 2014 | 06:56 PM
Coachramirez397's Avatar
Default Trouble with oil line on radiator
This is on a 1997 v90. The top line came off ok. The bottom line was trouble. I had to turn the large "nut" on the radiator. The small "nut" on the metal line is jammed on the line and will not spin. I would hate to have to replace this line. Any suggestions how to free it?
Old Oct 19, 2014 | 06:59 PM
Default The good oil line
This "nut" spins freely on the line. The other does not.
Old Oct 19, 2014 | 08:48 PM
Cactuslegs's Avatar
PB blaster, let it sit, then thread it back into the radiator some and with an oversized wrench or cresent give it some elbow grease. Use a cheater bar on the end if necessary.
Old Oct 20, 2014 | 07:03 PM
Tried pb blaster. When I try to turn the jam nut the line starts to bend and torque. Notice the paint flaking off. That is because the line is torquing and will kink or crack with too much force. I think I may just have to replace the line, but that sucker is over $100.
Old Oct 23, 2014 | 06:09 PM
Cactuslegs's Avatar
I'd try to find a used line at a local pick-your-part if you can. If not, I know some forum members frequent their local yard and have offered in the past to get parts for other people and ship them for only the cost of the part and shipping.
Old Oct 25, 2014 | 12:24 PM
lev's Avatar
lev
As with ALL heavily stuck parts, use heat, like an acetylene torch, carefully of course! At least this is an easily accessible spot. If that doesn't do it, you need to replace it.
Old Oct 26, 2014 | 08:31 AM
I heated it yesterday with a heat gun and freed it. Seems like paint on the line that chipped on installation was binding it. The more I work it around the more pieces work themselves out. Not sure if that's exactly it, but heat worked nonetheless.
Thanks everyone!
manoduv
Oct 10, 2013 09:00 PM
ccwtrainer
May 8, 2012 10:52 AM
jwzhp3
Jan 6, 2012 08:48 PM
KeithS60&V70T5
May 6, 2010 12:11 PM
bobcat123
Mar 13, 2010 05:18 PM
