Turn Signal Issue
Old Dec 7, 2010 | 08:26 PM
tate's Avatar
Default Turn Signal Issue
Have a 96 960 with 148K on the odometer. Recently, the turn signals have stopped blinking, the bulbs do light up. Prior to complete stoppage, the turn signals flashed at a fast rate. Occasionally, the turn signals will blink but generally light up only. Out of curiousity, I tried to turn on the hazard flasher lights, these also do not blink.
Thoughts?
Old Dec 8, 2010 | 11:43 AM
ed7's Avatar
ed7
You've got a flasher failure. Pull out the ash tray and the flasher is with the relays, behind the fuses. It's the third item in the second row. If you have a solder iron, resoldering the tabs on the circuit board may be all that is necessary.
Ed
Old Dec 9, 2010 | 11:50 AM
dan550i's Avatar
Beside the flasher being suspect, you might also verify that all four bulbs are functioning correctly, sometimes the sockets get melted and it might be shorting it out to the parking light system.
Pull each bulb, inspect the socket and the contact end of each bulb.
DanR '94 964 356,000 miles (122,000 on the new engine)
Old Dec 13, 2010 | 09:58 PM
Probably the bulb.
https://volvoforums.com/forum/showpo...33&postcount=6
racernick
Jun 20, 2022 09:43 AM
suckonthiscaravan
Dec 5, 2018 03:19 PM
brennanpersonal
Nov 4, 2009 10:33 AM
rspi
Sep 2, 2009 09:39 PM
NDan85
Sep 1, 2008 10:05 AM
