Weird electrical problem
Old Jul 27, 2013 | 10:43 PM
960 rookie's Avatar
Default Weird electrical problem
Hi-
So I have this weird electrical issue. Sometimes, I get in the car, start it up, and drive off- then as I get down the road I realize that my power windows don't work, nor do my turn signals. If I smack the top of the steering column, everything starts working again.
OK, so maybe I can understand some sort of wiring glitch in the column that would affect the turn signals, but what about the windows? Makes no sense that the window wiring would go through there.
Any thoughts? Similar problems?
Thanks-
Brady
Old Jul 28, 2013 | 05:50 AM
Old Jul 28, 2013 | 04:26 PM
danr960's Avatar
It does make perfect sense that the wiring passes through the ignition switch. You can't use your power window without the ignition being on, so what is happening is there are various relays that get powered through the ignition switch.
'94 964 387,000 miles (153,000 on the new engine)
RexD
Sep 17, 2014 02:17 PM
jmana
Jul 9, 2013 03:31 PM
swiftjustice44
Oct 25, 2012 06:32 AM
fq2255
Oct 15, 2011 11:34 PM
JFigliuolo
Mar 5, 2009 06:39 AM
