Weird Noise - 1994 960
Hello,
I took my 94 Volvo 960 back to the shop who worked on the breaks because they started squeaking after a week of driving and they were not effective. The shop owner said that he'll replace the pads and called me back saying the hoses need to be replaced for an additional charge of $200. I was upset that the hoses all of a sudden now need to be changed.
He replaced the pads and the breaks feel better the problem now is that the car used to start fine, now when I start it cold, I hear this weird scary noise coming from the engine, like dieseling and coarse ticking then it goes away few minutes later when the car is warmed up.
Could you please tell me what is this noise and how can I take the car back to redo the breaks and end up with this noise. Please help.
Hello,
Front or rear? Any vibrations? The mechanic should have cleaned and lubed the calipers. Did he? Hoses are about $ 10 each for each wheel. The front ones usually go bad. The rears not so much.
I think your cars is possessed with all these noises and smells that no mechanic can identify. On the noise -- do you have an air pump? Does the noise come from the engine or from other corners of the engine compartment?
Could be a roller in the timing belt path.
Timing belt replacement instructions on a 1997 Volvo 960
I had my timing belt replaced 23 months ago (about 27,000 miles ago). The reason I decided to do it again is that my idler was squealing. A couple of months ago it was only squealing when I started the car, lately it has been making noise even after the car was warm. I found out that the tensioner roller or idler roller can break or come apart, causing the same damage as if the belt breaks. I guess the mechanic I paid to do the belt last time did not replace the tensioner roller or idler roller. Not sure if I asked them not to or if they took it upon themselves not to. The tensioner roller spun very freely and felt like it had no grease in it. The idler roller was just about frozen, it was very hard for me to turn it with one hand. Both of these rollers should turn very smoothly and not spin by hand. I believe these bad rollers caused my water pump to leak.
This is from the Owner's Book:
"This engine features hydraulic valve lifters which means that valve clearance is adjusted automatically. It is possible that the valve lifters will produce a ticking sound for the first few seconds after the engine is started, while the oil pressure is increasing. If the car as not been used for a long period of time, this ticking sound may last for up to 15 minutes. This is entirely normal.
NOTE: Do not exceed 3000rpm until the ticking sound disappears".
Someone needs to listen to it, even use a stethoscope and find where the noise is coming from.
I took the car in today to a senior master technician who worked on our Japaneese cars, I can trust him very much. I thought he can just diagnose it and hopefully he'll figure things out. I'll let you know the outcome. Thank you.
The timing belt was done in July at 102k miles. Now it has 105k miles. The following items were replaced with the timing belt:
Idler pulley, hydraulic tensioner and water pump.
I took the car today to a different shop, family owned for 30 years and the service advisor has been working on Volvos over there for 19 years. He thinks that the noise is from the valves and he'll keep it overnight to start it cold and be able to listen to the noise as soon as it happens.
mordezmoncou
04-09-2007 05:07 AM
