Won't stay started
Won't stay started
I have a 1995 volvo 960. I had the spark plugs, oil and oil filter changed last Sunday (a friend did it). Seemed to run fine until Thursday am I went out to start it. Started fine but only ran for about a minute or two and died. Would not restart. It will start everytime it sits for a while however it will not stay started. Replaced fuel filter and air filter. Same problem. Only means of transportation! Any suggestions??
Hi and welcome to the site. I move your post to the 960 section, hopefully that will help you get some assistance.
Do you have a CEL? If so, you need to have those codes pulled. There is a OBD-I port under the hood.
Also, do you hear the fuel pump running? Did you try to start and run it with the MAF unplugged?
cdj111
07-16-2012 01:41 AM
