10K oil change interval?
Old Mar 6, 2013 | 07:11 PM
1995Volvo850's Avatar
Question 10K oil change interval?
I was considering going to the 10K oil change interval I remember reading about for the 2.4L in the owner's manual. What are the thoughts on this? BTW I use a semi-synthetic "high mileage" oil.
Thanks!
1995Volvo850
Old Mar 6, 2013 | 08:53 PM
ibified's Avatar
For the 30 bucks and 20 minutes, I'll stick with 5k, thanks.
Manual says 5k for the 2.3L, and 10K for the 2.4L I believe.
Old Mar 6, 2013 | 09:33 PM
You'll likely be fine if the driving style isn't severe. I would send a sample to Blackstone labs to test the oil. Wouldn't suggest it with a turbo but I did it once running full synthetic.
Old Mar 8, 2013 | 01:02 PM
grndslm's Avatar
People do 10K on conventional oil no problem. But they change their oil every 6 months.
From what I'm starting to see at BobIsTheOilGuy.com is that a 6 month interval is what is really preferred over distance. If you do start going way over 5K miles in a 6 month period, then perhaps synthetic would be a reasonable choice, however. Synthetic actually improves with time, but for the first 3K-4K miles or so, the oil won't have enough time to break down and show you what it's really made of.
Your driving style is of particular concern, as well. If most of your trips are less than 10 miles or so... you're not allowing the oil temps (not to be confused with coolant temps) to stay at operating temps long enough to burn off any condensation and things. Acids are another thing you don't want, but that cannot be burned off with longer drives. And this is why the 6 month recommendation is the better choice.
Also, I've seen it said that if you choose a quality oil filter, you will likely see better filtration by leaving it on there for 2 oil change intervals. Once the filter is lightly "clogged", that means less particulates will be getting through, as opposed to a brand new filter. If I had a turbo, tho... I would highly recommend changing the filter with every change, however.... just to make sure I don't do ANYTHING to affect the oil pressure. But I don't have a turbo, so..... yea.
Old Mar 8, 2013 | 03:00 PM
If you're going to run 10K between LOFs I'd recommend you do it on full synthetic. I know the factory stock recommendation for turbos is full synthetic but it might also be for NAs. If you look for sales on synthetic you can get a pretty good deal.
I would not recommend trying to go 20K on the filter. A good filter will start out trapping small particles and a clogged filter might filter better but it's because it's CLOGGED and you run the risk of starving your bearings of lubrication at higher RPMs when they need the volume and pressure most to prevent a failure.
Guys I know with high performance engines will drop the filter at 3/4K and add back in the "quart" they lost in the filter to go double but no one I know changes the oil and leaves the filter.
I've had and have also read others who have experienced lifter noise on start up using Frams. I would stay away from them.
And yes, these are THE GUYS when it comes to oil.
- Bob is the Oil Guy
Attached Thumbnails 10K oil change interval?-oil-autozone-synthetic.jpg   10K oil change interval?-oil-oreilly-synthetic.jpg   10K oil change interval?-oil-qt-castrol-edge-titanium.jpg
Old Mar 8, 2013 | 03:48 PM
grndslm's Avatar
That's how I used to do it. Change filter, top off, and go double on the oil.
But in terms of actually filtering the oil.... more and more people at BITOG are finding that a clogged oil is more "efficient" at filtering oil. Similar to a clogged fuel filter is more "efficient" at filtering fuel.
Obviously, you don't want to mess with the oil pressure, esp. in a performance engine... but ya never really know what's "best", or "most optimum", until you start doing oil analysis tests. I think Blackstones will even test filters directly, as well, but i'm not 100% sure on that.
BITOG is an awful lot like the Bible. You can find anything there to back up a certain point of view.
Old Mar 8, 2013 | 04:10 PM
ES6T's Avatar
I agree that I would never go that long on a filter. I have seen them start to come apart when customers decide they want to push the limits (and by push, I mean exceed) of their oil change interval.
Grndslm had a good point about driving style. I have seen plenty of customers go 8-10k and the stuff I drain out is nasty. But its mostly city driving and probably close to a year on the oil.
Old Mar 8, 2013 | 05:13 PM
JimKW's Avatar
My BMW calls for every 15K full synthetic. I do it every 7500 and use the BMW special grade oil by Mobil 1. Toyota I do every 6500K full synthetic. My Volvos I do every 3-4K semi-synthetic. It's easy to do and inexpensive. I buy filters by the case from fcp groton and I change the filter every time. Even if I switched to full synthetic I would not go more than 6000 on the Volvo. I can change that oil in about 10 minutes on the Volvo and the cost is probably about $25.
gbird911
Nov 8, 2013 11:49 AM
arpan17
Mar 13, 2012 02:49 PM
heybuddy
Mar 22, 2007 01:44 AM
Psaboic
Nov 27, 2006 03:53 AM
Psaboic
Oct 23, 2006 02:11 AM
