radiator drain plug
Old 01-28-2008, 02:08 PM
pollock's Avatar
Default radiator drain plug
I attempted to remove the radiator drain plug last night and the head of it twisted right off.
Anybody know where I can get a new one?
Old 01-28-2008, 02:40 PM
JimKW's Avatar
Default RE: radiator drain plug
I'd probably just get it from the dealer. If not fcpgroton would be my 2nd choice.
Old 01-28-2008, 04:50 PM
RedTurbo850's Avatar
Is this that plastic thing? I hate those. Mine broke also.
Old 01-28-2008, 08:42 PM
JPN's Avatar
JPN
JPN is offline
And if the remaining portion is still stuck in there, take a hex (allen) socket or equivalent, hammer it into the hex hole in the plug and you should be able to turn it off.
When you install it, all you need is finger tight + 1/16 to 1/8 turn. It is tempting but since it has an O-ring, it does not need to be tightened hard. If it leaks, give it additional 1/16 turn until leak stops.
JPN
jefhon
05-07-2018 06:17 PM
jbarnes
06-12-2013 11:46 AM
MrReality
04-05-2013 03:28 PM
VolvoT5er
02-16-2011 05:37 AM
roughyear
02-10-2005 10:02 AM
Quick Reply: radiator drain plug
