1994 850 Brake repair in progress, Loosened caliper brake fluid leaking out???
Old Jan 28, 2008 | 06:54 PM
Jomo1994z71's Avatar
Default 1994 850 Brake repair in progress, Loosened caliper brake fluid leaking out???
Guys,
Need a little help. My 1994 850 needs new brake pads in the rear. So i bought some and I took the out side half of the caliper off on the rear (4 bolts) and brake fluid was leaking out between the caliper... this is not normal? I have done brakes in the past but never did fluid leak on the ground. Any ideas...brakes are spongy as hell now...Plus is the inside half of the caliper just held on by 2 bolts because I couldn't get it off?
Thanks in advance...
Old Jan 28, 2008 | 07:00 PM
Default RE: 1994 850 Brake repair in progress, Loosened caliper brake fluid leaking out???
You need to bleed the system.
All you needed to do to replace the pads was pull the pins and push the piston back in and install new pads.
Old Jan 28, 2008 | 07:07 PM
Pull the pins?
Old Jan 28, 2008 | 07:13 PM
There is pins that go through the brake pads. All you need to do it tap them out and then back in after installing the new pads. The pins go over the Cross looking spring between the pads.
Old Jan 28, 2008 | 07:19 PM
RedTurbo850's Avatar
If your brakes are spongy, you have air in the system. As tech said, you need to bleed the brakes.
Also, our cars use Dot-4 not Dot-3 brake fluid.
Old Jan 28, 2008 | 07:21 PM
Alright guys,
Thanks,
I understand the spring part...now...to bleed the system just loosen the bleeder valve on top of the caliper. and tell the person in the car to push the brake pedal down about 3/4. then keep it there tighten the bleeder valve and repeat...
Old Jan 28, 2008 | 07:24 PM
Or you can have them pump the pedal about 5 times and hold it down then open the bleeder and have them tell you when it hits the floor then you tighten the bleeder.
Old Jan 28, 2008 | 07:28 PM
You are saying, pump the pedal 5 times about...hold it at the floor...then the guy at the back right bleeder screw open it, the pedal should sink(keep it there) tighten the bleeder screw
Please clarify thank you
Old Jan 28, 2008 | 07:33 PM
Yes after pumping up about 5 times the pedal should be pretty firm and when teh bleeder is opened the pedal will sink to the floor.
Old Jan 28, 2008 | 07:38 PM
Will do, will keep you updated...
Thanks again V-forum
Old Jan 28, 2008 | 07:39 PM
Glad we could help.
Old Jan 28, 2008 | 09:05 PM
JPN's Avatar
JPN
I use this.
JPN
[IMG]local://upfiles/6892/09381370E501421EBB3B6E51D4B239BF.jpg[/IMG]
danspies
May 17, 2018 05:49 AM
jcdill
Oct 11, 2014 09:27 PM
kelsodatrini
Jun 7, 2009 08:31 PM
Counselor828
May 18, 2009 09:58 PM
KINGI5T850
May 8, 2006 01:38 AM
