1995 850 Turbo no spark
Old Aug 7, 2011 | 01:09 PM
jsccinc's Avatar
Default 1995 850 Turbo no spark
I have a 95 850 Turbo that was given to me. the car ran fine when I last parked it. I went to start it a few months later and it won't start, it cranks over just fine. I checked for spark at the plugs with a tester and there is nothing. Can anyone steer in the right direction? I don't have a lot of time to waste searching for the cause.
Old Aug 7, 2011 | 01:40 PM
Oh, since you don't have time to do a search I'll just give you the information that I have seen over time.
Cam shaft sensor. It's located just under the upper torque mount at the end of the motor, cam. If you need a picture let me know and I'll fetch one.
Old Aug 9, 2011 | 06:42 PM
jsccinc's Avatar
Is there any way to test the cam sensor? I've checked all the grounds and still need to test the coil. Unfortunately I don't have a lot of money to spend on parts and have it still not run. I need to be sure that what i replace will fix the problem.
Old Aug 9, 2011 | 11:42 PM
gdog's Avatar
You're right; don't throw parts at it... this link might might help..
https://volvoforums.com/forum/volvo-...voltage-56508/
NoName
Oct 27, 2013 07:27 PM
taygarde
Nov 9, 2012 09:35 AM
volvoQ's
Apr 23, 2011 10:00 PM
futbolfan15
Apr 2, 2010 09:56 PM
vetalbig
Nov 26, 2007 12:33 PM
