1995 abs control module
Hello Everyone, I am a proud new owner of a 1995 850 turbo sedan, 97,000 miles. I've been reading a lot on this site and thanks for all the information.
My question is this,
My abs module(1995 turbo w/ tracs) seems to be out,
My ABS and TRACS warning lights go on and off intermittently,
I have found a 1994 module from an 850 turbo w/ tracs.
Will a 1994 ABS Module work in my 1995 ?
If you find a used one it is probably going to go out too. I would go ahead and pull the current one and send it off to be remanufactured. There are numerous people that do it. I used BBA Remanufacturing (found them on ebay).
The '93-'95 modules should beinterchangeable and the rebuilders won't touch them. Take a look at the module to make sure, the early style module has a metal case that is mounted vertically next to the ABS pump. The later style has a black plastic case that is mounted below the pump.
Before you replace the module pull the codes from Socket A-3. Many times just cleaning the wheel sensors will fix the problem on the earlier units.
...Lee
...Lee
