1995 Volvo 850 non-turbo
I am havin electrical problems with my 850. The highbeams and turn-signals dont work. I replaced the bulbs,fuses and even the switch itself and still nothing.further more the driver side turning lamp comes on and stays on when i engage the low beams which work correctly. checked with amp meter and no power in the front passenger-side turning lamp.Any suggestions,please help!:eek:
Check the bulbs. Make sure none of them in the front marker locations are like this:
https://volvoforums.com/forum/member...b-s90-2176.jpg |
I have already replaced the bulbs and fuses.went as far as replacing the switch on the column.there is no power present on the front passenger-side turning signal.but when i turn my low-beams on the front driver-side comes on until i disengage the low-beams.aslo no high-beams even though the bulbs are new.
Try to juggle the key in the ignition to see if that helps.
