1995 Volvo 850 non-turbo
Old Apr 1, 2012 | 07:51 PM
David Nye's Avatar
Default 1995 Volvo 850 non-turbo
I am havin electrical problems with my 850. The highbeams and turn-signals dont work. I replaced the bulbs,fuses and even the switch itself and still nothing.further more the driver side turning lamp comes on and stays on when i engage the low beams which work correctly. checked with amp meter and no power in the front passenger-side turning lamp.Any suggestions,please help!
Old Apr 1, 2012 | 07:58 PM
Check the bulbs. Make sure none of them in the front marker locations are like this:
Old Apr 1, 2012 | 09:43 PM
David Nye's Avatar
I have already replaced the bulbs and fuses.went as far as replacing the switch on the column.there is no power present on the front passenger-side turning signal.but when i turn my low-beams on the front driver-side comes on until i disengage the low-beams.aslo no high-beams even though the bulbs are new.
Old Apr 1, 2012 | 10:33 PM
Try to juggle the key in the ignition to see if that helps.
Ablorx
Jul 4, 2014 08:33 PM
twiin64
Jun 4, 2013 05:01 PM
taygarde
Nov 9, 2012 09:35 AM
twiin64
Jun 17, 2012 12:46 PM
Rayucd
Jul 27, 2008 11:43 PM
