1996 850 GLT Wagon won't start!
Old Nov 30, 2016 | 03:11 PM
CooperWalker's Avatar
Default 1996 850 GLT Wagon won't start!
I'm in LA, I left the car sitting a week and the battery died. I tried to jump it 3 times but it won't start! It turns over but does not click. I've had trans problems but these aren't related are they? Any help or advice is MUCH appreciated.
Old Nov 30, 2016 | 05:42 PM
firebirdparts's Avatar
When a car won't start, it's customary, if the engine is turning, to figure out if you've got fuel and whether you've got sparks. If the engine is not turning then that is a different line of reasoning, of course. My dad would say always consider if you're out of gas (cause sometimes you are)
If you don't have fuel, it'll still run on ether. That is a useful diagnostic.
The shop manual they have here https://www.volvoclub.org.uk/volvo_w...techdocs.shtml is pretty good on a no start, but it usually takes me about 10 tries to get the right one. Also, we learn things from the aging cars that they didn't know about when they wrote the manual.
Old Nov 30, 2016 | 05:44 PM
I got fuel... I refilled the tank less than a week ago. But I'll do some research and see if I can make sure there's fuel getting to the engine and whether there's spark getting to the engine.. Anything else I should do?
Old Nov 30, 2016 | 05:46 PM
PS the transmission only comes into it that there is a neutral start switch. The switch has to think it's in park or neutral for the starter motor to operate.
Old Nov 30, 2016 | 05:47 PM
That's helpful, thank you. I don't think that's the cause, the problem with the transmission is that the reverse gear is no longer working.
Old Dec 2, 2016 | 11:36 PM
Got it started, took 20 minutes to let the charge get through enough to crank it. I'm going to apply for the California BAR program, next get it smogged.
Old Dec 3, 2016 | 11:50 AM
bikerr's Avatar
New to this forum. Well at least in asking questions.I nave a 94 850 turbo. It wouldn't start,I guessed at coil being the problem,put in coil from my 93 Volvo and it solved the problem. that was about 4 mths ago. several days ago it happened again. put in new coil and car started,however after only 2 short trips it wouldn't start again. I put in new coil and it started. Well 3rd coil also only lasted 2-3 trips and now it won't start again. Could there be something that is making coil quit?. they cost 100.00$ and auto store is refunding my $...so far....
Old Dec 3, 2016 | 05:06 PM
Its actually kind of rare to have a coil fail - did you try replacing the wire set (I've seen the coil wire fail due to corrosion inside the end cap)? - also check the other wire connectors - it could have been you moved them during your R+R enough to give it a better (albeit temporary) connection. If you are really suspect - try putting a voltage meter to make sure the voltage regulator is not over charging.
Old Dec 4, 2016 | 10:46 AM
bikerr's Avatar
It was a poor wire from coil to distributor.Got quite a shock when testing,lol. Thanks for your response. Hopefully car parts store will refund $ for a second time.
VolvoWagonz
Jan 29, 2015 12:03 AM
walsh
Jul 22, 2013 07:30 AM
PoroPoika
May 3, 2013 01:19 AM
lgfarva83
Jan 26, 2011 05:54 AM
hoit666
May 23, 2009 01:28 AM
