1997 850—Dipstick Snapped in Reservoir
Mechanically Inclined:
I was changing oil in a 1997 Volvo 850 today, and just as I was finishing up the job, the dipstick snapped in the reservoir. It's pretty far down the tube, about an inch and a half or two. I didn't want to mess with it in fear that I would make it worse. I really need help with this. I do not want that dipstick to be stuck forever. Does anyone have any tips on how I can get this out? I've seen forums that suggest glue and a stick or sucking the dipstick out. But these do not seem plausible to me. Can I take it out by dropping the pan? Can I remove the dipstick reservoir? Thank you for any suggestions. |
Hi Arthur and welcome to the site.
I'm not sure what you mean by reservoir??? If you mean dip stick tube, you can pull the tube by pulling 1 bolt under the intake manifold then pulling the entire tube out. The bolt is a 12 mm and can be reached from up top. Some go at it from below but I think it's harder from there. |
Originally Posted by rspi
(Post 343268)
I'm not sure what you mean by reservoir??? If you mean dip stick tube, you can pull the tube by pulling 1 bolt under the intake manifold then pulling the entire tube out. The bolt is a 12 mm and can be reached from up top. Some go at it from below but I think it's harder from there. I second that or if you have a very small pair needle nose pliers that might fit into the tube should work to. |
If you pull the tube off you can push the dipstick out from the bottom it sticks out about 4 inches after the tube
| All times are GMT -5. The time now is 12:57 AM. |
