1997 850 T-5 Purchase Questions
Old Sep 23, 2008 | 11:09 AM
BCtransplant's Avatar
Default 1997 850 T-5 Purchase Questions
Hi all, I'm new to the forum, but after doing some reading here I think this is exactly what I need - you are a very knowledgable group…
I'm considering buying a 1997 850 T-5 AWD 5-spd Wagon, a combination that I had no idea actually existed. 224 000km, ABS module has been replaced, timing belt has been replaced, and the seller claims to have service records available, which I will be reviewing carefully for regular service (hopefully 5000km intervals.) I haven't looked at or driven it yet, but I will do so this week - if it passes my inspection I'll take it to the stealership for a detailed pre-purchase inspection.
One thing I'm somewhat concerned about is the Lambda light being on, according to the seller. The owner hasn't noticed any performance symptoms since the light came on. I asked whether he had pulled the codes - he hasn't but was told by the dealership, and I quote, that "the mass air flow meter or turbo pressure regulator need replacing."
This is obviously speculation, but this maybe indicates that the codes pulled were 1-2-1 or 4-1-4, based on the DTC listed in another post.
Obviously I'll have mofe info after driving & having it inspected, but is there anything I can do on-site to diagnose the above problem?
Thanks for any help, I look forward to getting more info up after the test drive.
Old Sep 23, 2008 | 08:48 PM
Maxbaby's Avatar
Default RE: 1997 850 T-5 Purchase Questions
Just to make sure, you really need to have that car inspected. The early AWD systems were prone to expensive problems from what I understand. Walk away if you notice mismatched tires. Apparently that can be the death-knell for that car's transfer case. At 200,000 km, a thorough inspection for that powertrain, but a very hot car if all checks out.
Old Sep 24, 2008 | 12:25 AM
Hmmmm, after a little more research it appears the AWD 850 is a pretty rare vehicle - maybe not available in the US at all?
Anybody have any specific input on checking danger signs for the AWD system? The mismatched tread wear is a good point - thanks.
Old Sep 24, 2008 | 02:35 AM
RedTurbo850's Avatar
ORIGINAL: BCtransplant
Just so you know, I don't know how it is in Europe, but I'm 90% sure that your car won't let you read the DTC readings. Your car should be OBD-II only and for more advanced codes, you need a Volvo Scan Tool.
Deathstar27
Apr 3, 2015 08:51 PM
momabug72
Jan 29, 2011 01:41 PM
LenA
Jul 25, 2010 12:54 AM
MAVA
May 7, 2008 10:10 PM
