1997 T5 Lifter Tick
Old Jul 21, 2015 | 10:19 AM
Annihilator's Avatar
Default 1997 T5 Lifter Tick
Hi all, I recently bought a T5 with about 132k on it. Compression was tested and was good. PCV system was clogged so had a Volvo mechanic replace it all and change oil. I did a couple light MMO flushes, then changed oil with Royal Purple 15w40 ($5 @ Autozone.) and a Mann filter.
After about a month, I notice ONE lifter tick from the center that's there even when warm. Has been ticking for a week now.
I'm thinking maybe oil pump/pan seals. Maybe the thick oil knocked some crud loose into the filter?
What do you guys think?
Old Jul 26, 2015 | 06:43 PM
why the thick oil? Yes the MMO treatment could have loosened up some sludge into the filter. What did you mean by "maybe oil pump/pan seals"? If you suspect low oil pressure you should try and measure with a gauge.
Old Jul 27, 2015 | 09:50 PM
Chicago summers tend to be hot so decided I'd rather have thicker than thinner oil.
My oil pressure light hasn't turned on or started blinking either. Is there a sticky on how to hook up a true oil pressure gauge?
Old Jul 30, 2015 | 09:34 PM
My bet is you'd need to remove the oil pressure sensor used for the light and insert a pressure tester that matches to the sensor's port size.
peace562
Feb 20, 2015 07:39 PM
pinkyjabberbox
May 28, 2012 11:50 AM
Moklomi
Jun 18, 2008 03:07 PM
rob960
Oct 9, 2007 07:46 PM
