2 "what is it" questions
Old Sep 26, 2005 | 05:50 PM
cranky's Avatar
Default 2 "what is it" questions
First one is: does anyone know anything about Yellow fuel injectors. I found info for orange, and white..... but not yellow.
Second question is: With the intake off the car, looking down the 5 ports, the lower half of each port has something I would describe as a flap. These flaps appear to be vacuum operated. What are these? How often do they cause problems?
Thanks for any info,
Cranky
Old Sep 27, 2005 | 10:09 PM
Default RE: 2 "what is it" questions
No info on the yellow ones either.
The flaps are most likely the Valves.
As long as you don't break the timing belt they will be fine.
Old Sep 28, 2005 | 10:48 AM
cranky's Avatar
Sorry guys, I've never been good at properly wording what I wanted to say.... I am trying
Ok, let me try to further explain those "flaps".
When looking into the 5 ports of the intake manifold - just inside the port opening, where the intake is bolted to the head, each manifold port appears to have an upper half, and a lower half. With the flaps closed, it seems that the air flow would be forced through the upper half of the port opening and across the fuel injector nozzles.
Thanks again.
Cranky
Old Sep 28, 2005 | 08:54 PM
Sorry I still don't get it.
Is there anyway you can take a picture and post it?
Old Sep 29, 2005 | 10:43 AM
cranky's Avatar
I will try to post a picture. I saw this intake at a salvage yard. The car was a 93 850. I plan to go back there today or tomorrow, so it may be a day or two before I can post a pic.
Thanks again.
cranky
Old Sep 29, 2005 | 09:28 PM
No problem I try to help the best I can.
Old Oct 5, 2005 | 12:57 PM
cranky's Avatar
In this picture I am holding the intake upside down, and using the vac solenoid to move the "flap" I am asking about. The line across the center of each port is part of the intake and doesn't move.
I have a Chiltons book on this car, and it doesn't show this, or mention it .
Cranky
Old Oct 5, 2005 | 09:50 PM
Never noticed it before must be part of an EGR system or something like that.Now I will have to find out it is bothering me now.
Old Oct 6, 2005 | 02:53 PM
cranky's Avatar
If it helps at all, this "flap" seems to be spring loaded in the open position, so it make sense that it would be closing at high vacuum, forcing the air past the fuel injector at a higher speed. The "flaps" are not metal, in fact I do not know what they are. They feel like high density cardboard - but considering the location, we know that is not what it is.
I know my original question sounded kind of crazy, but I assumed everyone knew about this thing. I have some experience turning wrenches, but mostly on GM stuff.
I would think that these flaps in the intake ports could be a good source of lower rpm power, or a power robbing piece of crap - depnding on how and when they operate.
Thanks, Cranky
Old Oct 7, 2005 | 10:20 AM
cranky's Avatar
This is a partial answer someone sent.
http://www.volvoclub.org.uk/tech/850...neTechInfo.pdf
Phil 850
Jul 25, 2012 10:01 PM
AnEskimo
Sep 25, 2010 08:32 AM
