4 lugs to 5 lugs
Old Jul 4, 2007 | 07:25 PM
glt93's Avatar
Default 4 lugs to 5 lugs
I see nice rims that have 5 lugs bad part I have a 1993 850 as you might know only has 4 lugs looking for acheap way to fix this problem
Old Jul 5, 2007 | 03:06 AM
JPN's Avatar
JPN
Default RE: 4 lugs to 5 lugs
A cheap fix example.
JPN
[IMG]local://upfiles/6892/44693814B72449E2A33B0294B3DCBAFB.jpg[/IMG]
Old Jul 5, 2007 | 03:38 AM
JPN's Avatar
JPN
I was just kidding, sorry.
Try following sites (Tire Rack did not have any available):
http://www.enkei.com/performance.html
http://www.wheelcollision.com/volvo4.htm
http://shop.wheelsrims.net/search.ht...pe=alloy_wheel
I did a bit of search, and as you've already noted, wheels for '93 850 seems rare to find. I am not sure if the 5-bolt hub/bearing unitcan be fitted onto '93 model without modification, but this is not a cheap option.
I would do a bit more search and if you couldn't find one, you may want to search what is called "multiple-hole" wheels, that have 8-10 lug holes to fit on both 4 & 5 lug wheels.
I hope this is of some use.
JPN
[IMG]local://upfiles/6892/505E3C382C72455E91AAEB2F7FFC68DD.jpg[/IMG]
Old Jul 7, 2007 | 11:56 PM
Dads850's Avatar
I've got a '93 myself and know your dilema, however I HAVE located aftermarket wheels here:
http://www.discounttiredirect.com/di...000618&bp=
If you want to go to 16's or 17's, there are even more options
http://superbuytires.com/v/Volvo/850+Series+4+Lug/1993/
http://www.thewheelconnection.com/php/wheelsearch.php
I knew about the discouttiredirect.com link because I'm thinking about getting the Konig Incident wheels.
T5wgn
Aug 4, 2012 07:29 AM
boxpin
Jun 3, 2010 10:31 AM
derekkoop
Jun 12, 2008 10:29 PM
johnboy1967
Dec 3, 2004 10:44 PM
