4 Questions for you:
First off: '96 850 GLT Wagon non-Turbo, 135,000 miles, relatively new battery and good connections on battery, running fine.
1) I'll start with the most urgent problem. I checked the oil today (which I don't do often enough, I've learned) and it didn't even hit the very bottom of the dipstick. Took my wife's car, got three quarts, put two and a half in.
Car doesn't smoke or smell of burnt oil. Oil warning light [bulb] works (comes on upon startup, then goes off with the other lights), but hasn't come on. No oil leak on bottom of car (rear main seal replaced three years ago and doing fine). A bit of oil around the filler cap, but it definitely hasn't been gushing out. ~ 4,000 miles since last oil change (was going to have it changed next week).
Question: Would it be too optimistic of me to assume cleaning the flame trap system would fix the problem?
2) I've been having some issues starting the car. It turns over just fine most of the time, but sometimes when I turn the key the starter won't engage. The actual starter works fine, and the engine comes on just quickly, but sometimes when I turn the ignition to start it won't do anything. All the warning lights come on like normal, and nothing dims when I hold the key in its furthest position, so no electricity is being used on something that's not working.
Is this a contact that's been fouled with years of carbon buildup? Where would I start the search?
3) My rear O2 sensor is faulty. How hard is it to change? I've tried to search this forum with replacement instructions but couldn't find any. Is it in front of the catalytic converter?
4) My radio reception. Woe is my radio reception. It picks up nothing when it scans, and barely picks up station I manually tune to. In some parts of the city it's fine, but in hilly or thickly wooded areas I get almost no reception on most channels. There is one station I pick up really well, but I attribute that to the station's antenna being about five miles away.
Is this a common problem? And is there an easy fix?
Thanks for your time!
1. Oil is either leaking static, under pressure, or being burned through your tailpipe. You have to figure poit which.
2. Starting, I think you said that is does NOT crank sometimes? You likely have a loose or corroded battery connection.
3. O2 sensors are pretty easy to change if you use an OEM sensor. There may be instructions on my site.
4. It's probably your radio. However, your antenna wire may be coming loose from the back of the radio.
1. Oil is either leaking static, under pressure, or being burned through your tailpipe. You have to figure poit which.2. Starting, I think you said that is does NOT crank sometimes? You likely have a loose or corroded battery connection.3. O2 sensors are pretty easy to change if you use an OEM sensor. There may be instructions on my site.4. It's probably your radio. However, your antenna wire may be coming loose from the back of the radio.
And I'll check the back of the radio tomorrow. Thanks again!
starting issue could also be the ignition switch - notorious for problems on these cars. A relatively easy fix.
Everything RSPI said is dead on though other than not mentioning that possibility.
Oh, and on the wagon, check to make sure the antenna is plugged in securely on the back glass on the driver's side. That could also be part of the problem.
By chance you have an ignition switch problem, usually they have accessory problems before they have starting problems. Have you been having problems like: a. Windows not wanting to roll down randomly? b. Gear shifter getting stuck sometimes? c. Lighting problems? You can try jiggleing the key while you hold it in the start position.
I'm new to wagons so I'm not sure how you can get to the window antenna wire connection? Maybe remove some trim.
Here is the link to my O2 sensor replacement: O2 Sensor on a 1995 Volvo 850 T-5 replacement instructions
^^ That does sound like the ignition switch. Try the jiggle trick to see if you can get the Shift Lock to work.
Here is the switch if you need to replace it, http://www.fcpgroton.com/product-exe...nuine+Volvo%29
S70driver
12-06-2006 01:53 AM
