65k gas in oil will not turn over???
Old Nov 15, 2004 | 11:12 PM
phil22's Avatar
Default 65k gas in oil will not turn over???
sorry if a FAQ but my 1996 850 has 65k (n/a 5 cyl) miles on it and it was running good, I just went and filled up with gas and 30 seconds later it started to idel funny and would not respond to the gas pedal then I saw some white smoke comming from the exhaust pipe so I shut if off. I towed it home and checked the coolant looked fine and the oil looked fine. So i tried to turn it over and it locked up. I then drained the oil and noticed a strong gas smell (actually saw gas fumes comming from the oil). Any thoughts???
thanks for the info guys.
-Phil D
Old Nov 16, 2004 | 12:14 AM
Default RE: 65k gas in oil will not turn over???
Two things i would check are if your fuel pressure regulator has a vaccum line going to it remove it and see if any gas comes out.There is a valve mounted on your cooling fan remove the hose and see if there is gas there.The hose for the valve comes from the intake goes into the valve then goes to the bottom of the car.
StantonGTI
Feb 17, 2014 04:08 PM
r171mb
Jun 15, 2013 10:51 PM
djais1801
Mar 15, 2011 01:52 PM
VoLvIzL
Aug 5, 2009 12:08 PM
Volvo240guy
Jul 7, 2007 12:12 AM
