Will not turn over
Old Dec 5, 2006 | 06:42 PM
Volvo240guy's Avatar
Default Will not turn over
I started my car and it was fine then when I tried later it would not start it would do not one thing. I took the batt to have checked and found that it need replaced also I got a new one put it in and the sME THING. Any way it is a 5 speed and I had some one to push and it stared right up what could that problem be please help !!!!!!
Old Dec 5, 2006 | 08:06 PM
JetTech's Avatar
Default RE: Will not turn over
The first thing that comes to mind is a bad spot on the starter solenoid. My starter was replaced before I bought the car so I know it went south at some point. If you tap on the solenoid with a screw driver handle or lightly with a small hammer and the car starts, you'll then be able to confirm that you'll need a new starter. Sometimes the tap method works and sometimes it doesn't. So if this doesn't bring it back to life, don't assume the starter is ok because my guess it's probably not. Good luck and I hope this helps.
Dale
Old Jul 1, 2007 | 10:49 PM
mike_01's Avatar
I had the same problem and it was the cilinoid, so I replaced it, with one of a dodge 2.4 starter,, they're interchangeable, and cheaper.
try shorting the 12volt wire from cilinoid to the 12 triger wire,, see if it does any thing
Old Jul 7, 2007 | 12:12 AM
VolvoDriver's Avatar
indeed i woudl imagine you could replace just the solenoid.
madtommom
Jun 16, 2012 07:06 PM
mrdabbas
Sep 18, 2011 12:00 AM
wags70ss
Jun 18, 2011 07:33 AM
VoLvIzL
Aug 5, 2009 12:08 PM
phil22
Nov 16, 2004 12:14 AM
