850 GLT Wont start.
#21
If you are located in Washington state you will likely get parts a lot quicker if ordered from www.iPDUSA.COM.
#22
FCP has their extended service kit on sale for $188 and free shipping.
Volvo 850 Service Kit-Buy Volvo Parts at FCP Groton
No way to promise that this will 100% solve your problem, but if it has been an unknown time since these items were changed, it needs to be done. These cars are very particular about worn ignition items.
Stage 0 is what you would do to make it how it was from factory..
You will need;
Cap
Rotor
Plugs (copper work better) & (gapped correctly)
Wires
air Filter
Fuel Filter
Clean PTC
PCV if it hasnt been done in a while.
Check all vac lines and elbows
there is other stuff that can be done but start there first
You will need;
Cap
Rotor
Wires
air Filter
Fuel Filter
Clean PTC
#23
to check if you need a PCV job done on you 850,when you car gets warm, pull the dipstick out, if there is smoke coming out from the hole that means you need your pcv replaced. its a lot of work and getting a volvo dealer to work on the pcv will break your bank account.if you can do it yourself that will save you alot of money.or you can get a personal mechanic who can help you save some money.where are u located?
#24
Also used the Auto parts stores computer today and my only fault code is P300 Random misfire detected. I pulled one of the spark plugs yesterday and it looks pretty bad so its time to change them. Then work on the rest of everything after i get my disability pay for next month.
#25
sorry to hear this brother.l know how that feels. it looks like you need a complete tune up.check your air filter and make sure its not clogged up, get volvo spark pugs from IPDUSA, you can get bosch or borgicourd wires from amazon for a pretty good price.thats what l did. also clean your MAF if you can because it helps.if you want your engine to breath better get K&N air filter,l did and noticed improvement.when was the last time you did a tune up?l asked you where you are located because l wanted to know if l could meet you somewhere and provide assistance if l can.but it looks like new york and washington is far.
#26
#27
#28
no problem brother. the best way to clean a maf sensor is to get a mass airflow sensor cleaner from autozon or any auto parts store.the MAF also plays part at starting your car.a bad MAF can cause hard starting.if you find it difficult on how to clean it just message me and l will make a video or take pictures on how to do it and email it to u. wish you could do a compression test to know the health of your motor.but take care of this problem first then we move from there. this is how it looks like.heres a link to amazon.so that you can have an idea on how it looks like.Good luck
http://www.amazon.com/CRC-05110-Mass.../dp/B000J19XSA
#29
I don't doubt his MAF should be cleaned, and could even be bad. Just want to be clear on this point.
#30
I bought a https://www.fcpgroton.com/product-ex...o_Tune_Up_Kit_ They have the best prices for the quality they offer that i have seen out of everywhere i have looked
Hopefully it should be here towards the end of the week or early next. I also added a fuel filter in the package. I will get the MAF cleaner tonight. I was also thinking of getting a couple bottles of SeaFoam one for the gas tank now then half in with the oil then half through a vacuum line right before i change out everything in that kit. Any other suggestions for now? Also thank you all for your help. I feel like this could all go into a car nightmare movie with me as the inexperienced hated car wrecker.
#31
dont run the seafoam in the vacuum now, wait till you get new spark plugs. because sometimes the engine misfires when its sucked through the vacuum lines. add 1/3 or it to your gas tank, and run it through the vacuum lines when you have new plugs installed.Clean the MAF first and see if it helps.
#34
Ok Did a tune up. Replaced all this
If anyone wants to see what SeaFoam does with your exhaust while your burning it out of your engine.https://docs.google.com/open?id=0B8O...S1lM1BWeUVBVTA
- Distributor rotor
- Distributor Cap
- Spark plugs
- Spark plug wires
- Air Filter
Fern Schmidt
2001-2013 model year V70
08-13-2013 06:43 PM
furball3
01-28-2007 03:31 AM
