850 roof molding - ideas?
Old May 23, 2010 | 01:07 PM
Casmith's Avatar
Default 850 roof molding - ideas?
The black molding along the sides of the roof line are coming apart on my wagon. It is chrome-looking underneath. I was wanting the fix this. Does anyone have any ideas? I thought about peeling it off and painting it black. I also thought about painting it with some rubber stuff, like a paint-on bedliner. I think it may wear better, but it may be a pain to do it without it looking sloppy. Or maybe somewhere there is a way to order a new piece to put on...I'm not sure.
Anybody have any ideas or experience with redoing/restoring this?
Thanks
Casmith
Old May 23, 2010 | 05:51 PM
silkhope's Avatar
I need to do mine also, I saw a thread/sticky somewhere on how to do this. Does anyone remember seeing it. How do you get the trim off (tech, anybody)?
Old May 23, 2010 | 07:08 PM
Bobec's Avatar
I have a wild idea, I just need to take mine off to have a look at it below the surface. yes, I have the same problem. I'll take it off tomorrow morning and let you know if my idea holds any water.
Old May 23, 2010 | 11:07 PM
91shelby's Avatar
+1 how do you get if off without breaking it?
Old May 24, 2010 | 05:59 AM
Bobec's Avatar
Starting at the windshield carefully pull it straight up, it's just clipped in. Careful around the fender but it will come out from under it.
My idea won't work, I was thinking of using black heat shrink tubing. I'm going to try black striping tape but paint might work too.
Old May 24, 2010 | 07:56 AM
JimKW's Avatar
The absolute best thing you can do is find a 98-99 V70 and get the strips from that. They fit perfectly and will not peel and they have the little trough on the drivers side so rain does not come in your side window when you have your windows cracked during the rain or even when you wash your windows. I have S70 strips on both my 850's.
Old May 24, 2010 | 09:35 AM
vjaneczko's Avatar
This is a little project that has recently been added to my ToDo list. I've read that a lot of people have used electrical tape for a quick fix, but it fails quickly, too. My plan is to pull it off, sand it down a bit and paint it with a rubberized paint. Duplicolor, 3M and a few others have a rubberized undercoat spray that I'm interested in. I just need to see if they spray on smooth or textured.
Old May 24, 2010 | 12:01 PM
JimKW's Avatar
Several people painting them have talked about masking them off on the car. They are super easy to remove and that would make painting them much easier. For some reason I don't think the black tape idea is that good.
Old May 24, 2010 | 01:05 PM
ibified's Avatar
I did pretty much exactly what the original poster said: I took mine off, stripped them down to the bare metal, then scuffed them with a scotchbrite pad, masked off the rubber molding on the sides, and painted them with bedliner.
The easiest way to get the black stuff off that I found was a box knife blade. I just moved it back and forth over the areas that still had black on them and worked it off. Masking and painting was easy, and I'm VERY happy with the outcome.
Old May 24, 2010 | 04:56 PM
Casmith's Avatar
Thanks for the input. I will probably check Pull-a-Part, and if they don't have a V70 with a decent pair, I will tape it off and paint it with the bedliner. I think that will last longer than just about anything.
Thanks
Casmith
Old Jun 14, 2010 | 07:30 PM
vjaneczko's Avatar
Originally Posted by ibified
. . and painted them with bedliner.
How'd they look with the bedliner spray? Does it have a mat finish? If it does, what brand did you use?
Old Jun 14, 2010 | 10:25 PM
Default Roof line trim replacement
Jim, are you kidding me??? I really HATE my trim that allows the rain to come into my side windows from the windshield. And my S70 has the best ones. Do the S70 trim pieces really fit, if so, I will order some for my 850 as soon as I get paid next week.
Old Jun 14, 2010 | 10:27 PM
Here is the link to the proceedures in the sticky: https://volvoforums.com/forum/showpo...2&postcount=32
Old Jun 15, 2010 | 01:33 AM
ibified's Avatar
Vjan: i used the duplicolor spray can bedliner. Easy to do.....sorry for the poor quality of the pic, but it's night time.
Attachment 2694
Attachment 2695
Old Jun 15, 2010 | 08:45 AM
vjaneczko's Avatar
Wow, it looks almost like new! Nice job. Now I know what to get! Thanks.
Old Jun 15, 2010 | 12:21 PM
ibified's Avatar
The finish product is 100% dependent on the prepwork you do. I made sure i had ALL the old black stuff off of them, plus I scotchbrighted them. Yhen I masked them off very carefully so I wouldnt get any on the rubber molding thats on them. That step is kinda a pain in the ****, since they are so long. Just make sure that you mask them off perfectly.
Old Jun 15, 2010 | 12:48 PM
  #17
I just priced the parts for my S70 and they cost $161.90 each. My stealer is the highest I know of so they should be cheaper anywhere else. My Volvo yard said $25 a piece.
Old Jun 15, 2010 | 07:55 PM
  #18
JimKW's Avatar
Just fine a used car and get them off of it. I have them on both my 850's. Now I don't have to put my windows up to do my window washers and they don't peel and they seem to stay black much better too.
Old Aug 5, 2010 | 09:33 AM
  #19
TacklaNHL's Avatar
I have a pair of these roof trim rails... complete with all the clips... uncracked and not peeling at all...
FOR SALE: $50 +shipping
Old Mar 29, 2011 | 10:51 AM
  #20
I got a pair of the S70 rails from our Volvo Yard and they fit great. They are better because they have deflectors along the windshield to direct the rain over the car instead of inside the windows when wet.
hovonogila
May 16, 2019 02:28 AM
mightyjak
2001-2013 model year XC70
Jan 14, 2014 05:24 PM
gatorloverone
Dec 18, 2008 07:18 PM
Jalfred
Jun 12, 2006 09:09 PM
etype38
Jun 15, 2005 12:37 AM
