850 and s70 bolt patterns the same?
Old May 11, 2009 | 01:57 AM
keyul's Avatar
Default 850 and s70 bolt patterns the same?
Hi guys, I just had a quick question about the bolt patters on an 850 and an s70. I found a set of 16" wheels for an s70 and was wondering if they have the same bolt pattern as my 850 and if both cars used the same wheel offset? My 850 currently has 15" steelies on it with 195 tires but it is supposed to have the 16" wheels with 205 tires according to the sticker.
Keyul
Old May 11, 2009 | 03:00 AM
S70driver's Avatar
What year is your 850? I know 1995-1997 850's and the 1998-2000 s70's share the same bolt pattern of 5x108mm, as for the offsets being the same I cannot answer that for you. Tech might be able to.
I believe the 1993 850's had a different bolt pattern I believe a four lug pattern. The 1994's might of had the 5 lug pattern like the 1995-1997 models did. Again Tech might be able to answer this for you as well. Or shall I say confirm what I am saying.
Old May 11, 2009 | 07:58 AM
JimKW's Avatar
94-97 are the same. Only the 93 had the four bolt pattern.
Old May 11, 2009 | 10:53 AM
keyul's Avatar
Mine is a 97, thanks for your helps guys, I am going to go take a look at these today.
tuner4life
Apr 27, 2012 06:41 PM
Counselor828
Aug 22, 2011 12:19 PM
freq
May 14, 2011 07:03 AM
alex57
Aug 8, 2010 12:05 PM
OlDrifter
Mar 16, 2008 10:06 PM
