850 stalls
Old Apr 10, 2008 | 01:29 PM
dumpling's Avatar
Default 850 stalls
Went to 2 volvo pro's and they found nothing. Keeps setting 214 code and intermittent stall no rhyme or reason. Replaced main relay, factory crps sensor, they tried a different computer, and cam sensor. What next?
thanks for the help.
Old Apr 10, 2008 | 02:15 PM
Ozark Lee's Avatar
Default RE: 850 stalls
There was a TSB a few years ago that dealt with that. It calls for using a ty-wrap to secure the lead from the crankshaft position sensor well away from the ignition wires. In its natural state it wants to loop up near the distributor cap where its signal can be interfered with.
It is my kinda repair, real cheap and real easy.
...Lee
Old Apr 11, 2008 | 08:42 AM
jquick1's Avatar
Well what about when it will ONLY stall in the summer. My 96 850T will only stall when it gets warm out. went to auto zone to get the codes, and the only one was a 440. i have tryed to find it but no luck. thx for your help
Old Apr 11, 2008 | 10:08 AM
JPN's Avatar
JPN
I cannot find code P440 in my factory manual.
Hot climate puts strain on the engine, especially if it's a turbocharged one. Stalling could be due to many things and could be due to either one fault or multiple faults. I would check the cooling system, fuel system, induction system & ignition system. Some cars are more vulnerable to vapour lock in the fuel line.
See attached FYR.
JPN
[IMG]local://upfiles/6892/D1C3D124CF56404BBA8899E48D6B5F95.jpg[/IMG]
[IMG]local://upfiles/6892/A49203D915A94286808000375EA78D34.jpg[/IMG]
Old Apr 11, 2008 | 01:30 PM
Quick Brick's Avatar
Hey now.
Here is a list of codes:
A1
Transmission
A2 Fuel System
A3 ABS
A5 Transmission Control
A6 Ignition System
A7 Combined Instrument
B1 Climate Control
B2 Cruise Control
B5 SRS
B6 Power Seat
Instructions on how to read and reset codes.
Automatic Transmission Fault Codes A1
CODE MEANING
1-1-1 No fault detected
1-1-2 Solenoid S1 circuit shorted to 12 volts
1-1-3 Fault in ECU
1-1-4 Break in driving mode selector circuit
1-2-1 Solenoid S1 circuit shorted to earth
1-2-2 Break in solenoid S1 circuit
1-2-3 Solenoid STH circuit shorted to 12 volts
1-2-4 driving mode selector circuit shorted to earth
1-3-1 Break or short circuit to earth in solenoid STH circuit
1-3-2 Fault in ECU
1-3-4 Incorrect load signal
1-4-1 Oil temperature sensor circuit shorted to earth
1-4-2 Break in oil temperature sensor circuit
1-4-3 Kickdown switch circuit shorted to earth
2-1-1 Fault in ECU
2-1-2 Solenoid S2 circuit shorted to 12 volts
2-1-3 Throttle position signal too high
2-2-1 Solenoid S2 circuit shorted to earth
2-2-2 Break in solenoid S2 circuit
2-2-3 Throttle position signal too low
2-3-1 Irregular throttle position signal
2-3-2 Vehicle speed sensor signal absent
2-3-3 Incorrect speedometer signal
2-3-5 Oil temperature too high
2-4-5 Break or short circuit to earth in torque limiting circuit
3-1-1 Transmission RPM sensor signal absent
3-1-2 Transmission RPM sensor signal faulty
3-1-3 incorrect signal from gear position sensor
3-2-2 Incorrect gear ratio for given road speed
3-2-3 lock up slips or not engaged
3-3-1 Solenoid SL circuit shorted to 12 volts
3-3-2 Break in solenoid SL circuit
3-3-3 Solenoid SL circuit shorted to earth
Motronic 4.3 System A2
CODE PROBABLE CAUSE (for Volvo vehicles)
1-1-2 ECU faulty
1-1-5 faulty signal to No. 1 cylinder injector
1-2-1 MAF sensor signal absent or faulty
1-2-3 Coolant temperature sensor signal absent or faulty
1-2-5 faulty signal to No. 2 cylinder injector
1-3-1 Engine RPM sensor signal absent or faulty
1-3-2 Battery voltage too low or too high
1-3-5 faulty signal to No. 3 cylinder injector
1-4-3 Front knock sensor signal absent of faulty
1-4-4 load signal absent of faulty (fuel system)
1-4-5 faulty signal to No. 4 cylinder injector
1-5-2 air pump valve signal absent or faulty
1-5-4 Leak in EGR system (leakage or excessive flow)
1-5-5 faulty signal to No. 5 cylinder injector
2-1-2 heated oxygen Sensor Signal absent or faulty
2-1-4 Engine RPM sensor signal absent intermittently
2-2-3 Idle air control valve signal absent or faulty
2-2-5 A/C pressure sensor signal absent or faulty
2-3-1 Long term fuel mixture too lean or too rich in part load stage
2-3-2 long term fuel mixture too lean or rich at idle
2-3-3 long term idle airs trim outside control range
2-3-5 EGR controller signal absent or faulty
2-4-1 EGR system flow fault
2-4-3 throttle position sensor signal outside of voltage range
2-4-4 Knock control at limit
2-4-5 idle air control valve closing signal faulty/absent
3-1-1 Vehicle speed sensor signal absent
3-1-3 EVAP valve signal absent or faulty
3-1-4 Camshaft position sensor signal absent or faulty
3-1-5 EVAP emission control system fault
3-2-3 Malfunction indicator lamp signal faulty
3-2-5 ECU memory loss
3-3-5 request for Malfunction indicator lamp signal from auto transmission ECU
3-4-2 air conditioning system relay control signal fault
3-4-3 fuel pump relay control signal faulty
4-1-1 Throttle position sensor signal outside of voltage range
4-1-3 EGR temperature sensor signal absent or faulty
4-1-4 Turbo boost pressure too high
4-1-6 Turbo boost reduced by auto transmission ECU
4-3-2 High temperature inside ECU module box
4-3-3 rear knock sensor signal absent/faulty
4-3-5 heated oxygen sensor response too slow
4-4-2 air pump relay signal absent or faulty
5-1-1 long term fuel mixture too rich at idle
5-1-2 short term fuel mixture too rich
5-1-3 Excessively High temperature in ECU module box
5-1-4 Engine cooling fan faulty at half speed
5-1-5 Engine cooling fan faulty at full speed
5-2-1 Oxygen sensor heating faulty
5-2-3 signal to ECU module box cooling fan shorted to 12 volts
5-2-4 transmission torque control signal faulty
5-3-5 turbo regulator valve fault
5-4-1 EVAP valve signal fault
ABS and TRACS fault codes A3
CODE MEANING
1-1-1 No Fault Detected
1-2-1 LH Front Wheel Sensor – faulty signal at speeds less than 25 mph (40 km/h)
1-2-2 RH Front Wheel Sensor – faulty signal at speeds less than 25 mph (40 km/h)
1-2-3 LH Rear Wheel Sensor – faulty signal at speeds less than 25 mph (40 km/h)
1-2-4 RH Rear Wheel Sensor – faulty signal at speeds less than 25 mph (40 km/h)
1-4-1 Faulty Brake Pedal position sensor, shorted to earth or supply
1-4-2 Faulty stop light switch, open circuit or short circuit
1-4-3 ECU memory fault
1-4-4 Brake discs overheated (cars with TRACS only)
2-1-1 LH Front Wheel Sensor – no signal when moving off
2-1-2 RH Front Wheel Sensor – no signal when moving off
2-1-3 LH Rear Wheel Sensor – no signal when moving off
2-1-4 RH Rear Wheel Sensor – no signal when moving off
2-2-1 LH Front Wheel Sensor – no signal from ABS system
2-2-2 RH Front Wheel Sensor – no signal from ABS system
2-2-3 LH Rear Wheel Sensor – no signal from ABS system
2-2-4 RH Rear Wheel Sensor – no signal from ABS system
3-1-1 LH Front Wheel Sensor – open circuit or short circuit
3-1-2 RH Front Wheel Sensor – open circuit or short circuit
3-1-3 LH Rear Wheel Sensor – open circuit or short circuit
3-1-4 RH Rear Wheel Sensor – open circuit or short circuit
3-2-1 LH Front Wheel Sensor - intermittent signal at speed over 25 mph (40 km/h)
3-2-2 RH Front Wheel Sensor - intermittent signal at speed over 25 mph (40 km/h)
3-2-3 LH Rear Wheel Sensor - intermittent signal at speed over 25 mph (40 km/h)
3-2-4 RH Rear Wheel Sensor - intermittent signal at speed over 25 mph (40 km/h)
4-1-1 Inlet valve for LH front brake, open circuit or short circuit
4-1-2 Return valve for LH front brake, open circuit or short circuit
4-1-3 Inlet valve for RH front brake, open circuit or short circuit
4-1-4 Return valve for RH front brake, open circuit or short circuit
4-2-1 Inlet valve for rear brakes, open circuit or short circuit
4-2-2 Return valve for rear brakes, open circuit or short circuit
4-2-3 TRACS valve, open circuit or short circuit
4-2-4 TRACS pressure sensor, faulty or short circuit
4-4-1 ECU processing fault
4-4-2 Hydraulic modulator pump pressure low
4-4-3 Electrical or mechanical fault in hydraulic modulator pump motor
4-4-4 No power supply to hydraulic modulator valves
Transmission Control Codes A5
CODE MEANING
2-4-2 Turbocharger control valve signal absent or faulty
3-1-2 No knock signal from ignition control module
3-4-2 A/C blocking relay signal absent or faulty
4-2-1 Boost pressure signal in control module faulty
4-2-3 Throttle position sensor signal outside voltage range
4-2-4 Fuel control module load signal absent or faulty
4-3-1 Radiator temp sensor signal absent or faulty
Ignition Codes A6
CODE MEANING
1-1-1 No DTC set
1-1-2 Control Module fault
1-2-3 Engine Coolant Temperature Sensor from Control module missing or faulty
1-3-1 Engine speed (RPM) sensor signal missing
1-4-2 Control Module Fault
1-4-3 Knock sensor missing or faulty
1-4-4 Ignition control module load signal missing
1-5-4 EGR system flow too high in system
2-1-4 Engine speed (RPM) sensor signa
Old Apr 11, 2008 | 03:22 PM
92Typhoon's Avatar
What are the symptoms leading up to the stall? When our Volvo was stalling out, it would cruise, then stutter and buck just before it died, most of the time. It ended up being vacuum line related, so you might have your mechanic go over all your vacuum lines and check for cracks, leaks or breaks.
rainman14624
Sep 20, 2010 09:22 PM
Alex11
Mar 18, 2009 09:20 AM
kirkgrau
May 27, 2008 03:10 PM
bunjamins
Aug 27, 2006 03:22 PM
debcosta
Nov 27, 2005 08:42 PM
