850 Turbo rear mount
Old Apr 14, 2012 | 02:52 PM
aleksey17's Avatar
Default 850 Turbo rear mount
Has anybody replaced the rear lower motor mount on a 850 turbo? Does the turbo have to come off to get to the top bolt? I need to change mine as my engine is sagging and the transmission is resting on the sub frame and I am getting a lot of vibration now. From looking at it I think the turbo has to come off, but if there is a way without removing the turbo someone please let me know. Thanks
Old Apr 14, 2012 | 06:37 PM
Which mount are you talking about? The rear subframe mount, "A"?
Old Apr 16, 2012 | 08:31 PM
aleksey17's Avatar
Yes that's the mount, I tried but no luck getting to the bolt/nut on top. The turbo pretty much sits on it
Old Apr 16, 2012 | 09:03 PM
MattyXXL's Avatar
you have to loosen the bracket on the block and lift the motor... same as the front but you loosen the bracket then pull the mount off
240nc
Mar 4, 2015 08:58 PM
tuner4life
Apr 27, 2012 06:41 PM
Bboble
Nov 8, 2006 09:44 PM
Red XC
Apr 8, 2006 03:11 PM
