855tm:rpm hangs between shifts?
Hi all
I have a 1995 850 turbo manual. If I rev to say 3000 rpm then step on the clutch as to shift the rpm stays at 3000 rpm for 2-3 seconds then drops to idle speed,every time. I have connected a smoke generator to the intake and did not find any significant vacuum/boost leaks.Cable throttle returns quickly and smoothly. I did just instal this engine from another car. Otherwise the engine runs great and has good power. No trouble codes. Anyone else experience this?:confused: Any suggestions welcome. |
Tell me more about this smoke generator???
smoke machine:a device that produces white smoke,kind of like a disco fog generator on a smaller scale.
connect it to the intake(or any other closed system(gas tank/evap,crankcase)) via a vacuum hose and block off the air intake at MAF sensor wherever smoke comes out you have a leak that probably needs repairing |
Good thing I have not put away my Halloween stuff yet.
