855tm:rpm hangs between shifts?
Old Nov 9, 2009 | 09:19 PM
powertoweight's Avatar
Question 855tm:rpm hangs between shifts?
Hi all
I have a 1995 850 turbo manual.
If I rev to say 3000 rpm then step on the clutch as to shift the rpm stays at 3000 rpm for 2-3 seconds then drops to idle speed,every time.
I have connected a smoke generator to the intake and did not find any significant vacuum/boost leaks.Cable throttle returns quickly and smoothly.
I did just instal this engine from another car.
Otherwise the engine runs great and has good power.
No trouble codes.
Anyone else experience this?
Any suggestions welcome.
Old Nov 9, 2009 | 10:40 PM
boxpin's Avatar
Tell me more about this smoke generator???
Old Nov 10, 2009 | 12:13 AM
smoke machine:a device that produces white smoke,kind of like a disco fog generator on a smaller scale.
connect it to the intake(or any other closed system(gas tank/evap,crankcase)) via a vacuum hose and block off the air intake at MAF sensor
wherever smoke comes out you have a leak that probably needs repairing
Old Nov 11, 2009 | 10:49 AM
boxpin's Avatar
Good thing I have not put away my Halloween stuff yet.
Rob G.
Apr 2, 2011 12:44 AM
Rob G.
Mar 29, 2011 07:42 PM
gilber33
Aug 15, 2010 04:56 PM
audios
Aug 19, 2005 08:01 PM
