94 850 cruise control
I have only used diagnostic port A to help with some issues. I understand that diagnostic port B, position 2, relates to cruise control. How, or can, I use this port to figure out why the cruise control in this car is inoperative? If so, how? Thanks!
RE: 94 850 cruise control
You use the wire attached to A port you stick it in B2 and pull the codes.
But take the car for a drive and try to activate the cruise. Then WITHOUT shutting the car off after the test drive pull the codes. That should lead in a direction to look. |
Great! Thanks a million!!
