94 850 cruise control
Old Jan 19, 2009 | 09:32 PM
trooperone's Avatar
Default 94 850 cruise control
I have only used diagnostic port A to help with some issues. I understand that diagnostic port B, position 2, relates to cruise control. How, or can, I use this port to figure out why the cruise control in this car is inoperative? If so, how? Thanks!
Old Jan 19, 2009 | 09:47 PM
Default RE: 94 850 cruise control
You use the wire attached to A port you stick it in B2 and pull the codes.
But take the car for a drive and try to activate the cruise. Then WITHOUT shutting the car off after the test drive pull the codes. That should lead in a direction to look.
Old Jan 19, 2009 | 10:22 PM
trooperone's Avatar
Great! Thanks a million!!
rjv5n
Jun 20, 2010 11:16 PM
rspi
Mar 7, 2010 06:13 PM
jfikentscher
May 31, 2006 09:58 PM
CFGVolvo850
May 24, 2005 12:38 AM
