94 850 needs better gas mileage
I have a 94 850 non-turbo that is getting horrible gas mileage. I had a new used engine put in with 77k miles on it. Before I had that put in I was getting between 25-30mpg and now I'm lucky to get 20mpg. Is there anything I can check or replace that will help this out? If something similar is posted somewhere, please direct me because I searched back a few pages and couldn't find anything. Thanks for the help.
RE: 94 850 needs better gas mileage
Are those hwy or city driving specs? If city, 20 is decent, I get 20-21 if I don't stomp the gas on green lights. Highway I get 24-26. I shouldn't say I get this mileage, my wife does. I like to use the turbo too muchhttps://volvoforums.com/micons/m9.gif
If you were getting 30, holy cow dude, I'd post the question too! But I think now you may be on average mpg. 95 850 Turbo Wagon. |
If the car otherwise seems to run good the first place I would look on a non turbo is the airbox thermostat. If it hasn't been replaced it has almost certainly failed and it is drawing in hot air all of the time. I just jammed mine to the cold side.
The extra power and better mileage was immediate. ...Lee |
20mpg is on the interstate with the cruise control set right at 70mph. City driving is around 15mpg. Not good at all. I'll have to check that airbox thingy. I did replace the "normal" thermostat this winter when my heater stopped heating my car.
I have a stick so my final drive ratio is a tad higher but I routinely get 30 - 31 MPG on the highway at 70 to 80 MPH.
A good thread on the airbox thermostat is here, it has some pictures of what is going on as well: http://www.matthewsvolvosite.com/cha...pic.php?t=8830 ...Lee |
When was the last complete tune up? Plugs, wires, cap, etc.? Those can have a huge effect on gas mileage. Also, when was the last time you changed your airfilter? A good clean filter can add some mpg's as well.
I would start with a basic tune up and air filter if you don't know the last time they were done and go from there. :) |
My last tune up was a little less than a year ago when the "new" used engine was put in. He replaced belts and plugs and filters.
And my check engine light has been on since then...but that's a different story. If I took it to a Volvo shop, what can I expect to spend on a full tune-up? |
Why would you want to go to a Volvo shop to do a tune up? It´s just a matter of buying a tune up kit and installing the parts. It is very simple and you do not need any "special" tools.
Do you still have the service receipt/report that tells you exactly what parts they replaced?
JPN |
I would do in order....
1. Check the airbox thermostat 2. Check the tire pressure and set to about 35 psi all around (low tire pressure, even 3-4 pounds will cause quite a drop in fuel economy) 3. Check for fuel leaks 4. Do a full tune up (use OEM volvo plugs, and MANN filters) a good place for parts is fcpgroton.com, ipdusa.com, or autohausaz.com 5. Keep us posted. Glenn |
