94 850 needs better gas mileage
Old Apr 16, 2008 | 02:37 PM
Super20's Avatar
Default 94 850 needs better gas mileage
I have a 94 850 non-turbo that is getting horrible gas mileage. I had a new used engine put in with 77k miles on it. Before I had that put in I was getting between 25-30mpg and now I'm lucky to get 20mpg. Is there anything I can check or replace that will help this out? If something similar is posted somewhere, please direct me because I searched back a few pages and couldn't find anything. Thanks for the help.
Old Apr 16, 2008 | 03:04 PM
gooproduct's Avatar
Default RE: 94 850 needs better gas mileage
Are those hwy or city driving specs? If city, 20 is decent, I get 20-21 if I don't stomp the gas on green lights. Highway I get 24-26. I shouldn't say I get this mileage, my wife does. I like to use the turbo too muchhttps://volvoforums.com/micons/m9.gif
If you were getting 30, holy cow dude, I'd post the question too! But I think now you may be on average mpg.
95 850 Turbo Wagon.
Old Apr 16, 2008 | 03:06 PM
Ozark Lee's Avatar
If the car otherwise seems to run good the first place I would look on a non turbo is the airbox thermostat. If it hasn't been replaced it has almost certainly failed and it is drawing in hot air all of the time. I just jammed mine to the cold side.
The extra power and better mileage was immediate.
...Lee
Old Apr 16, 2008 | 03:30 PM
Super20's Avatar
20mpg is on the interstate with the cruise control set right at 70mph. City driving is around 15mpg. Not good at all. I'll have to check that airbox thingy. I did replace the "normal" thermostat this winter when my heater stopped heating my car.
Old Apr 16, 2008 | 05:16 PM
Ozark Lee's Avatar
I have a stick so my final drive ratio is a tad higher but I routinely get 30 - 31 MPG on the highway at 70 to 80 MPH.
A good thread on the airbox thermostat is here, it has some pictures of what is going on as well:
http://www.matthewsvolvosite.com/cha...pic.php?t=8830
...Lee
Old Apr 16, 2008 | 05:17 PM
92Typhoon's Avatar
When was the last complete tune up? Plugs, wires, cap, etc.? Those can have a huge effect on gas mileage. Also, when was the last time you changed your airfilter? A good clean filter can add some mpg's as well.
I would start with a basic tune up and air filter if you don't know the last time they were done and go from there.
Old Apr 16, 2008 | 09:50 PM
JPN's Avatar
JPN
See my 2nd reply at:
https://volvoforums.com/m_48928/tm.htm
JPN
Old Apr 19, 2008 | 11:30 PM
Super20's Avatar
My last tune up was a little less than a year ago when the "new" used engine was put in. He replaced belts and plugs and filters.
And my check engine light has been on since then...but that's a different story. If I took it to a Volvo shop, what can I expect to spend on a full tune-up?
Old Apr 20, 2008 | 06:35 AM
axelm's Avatar
Why would you want to go to a Volvo shop to do a tune up? It´s just a matter of buying a tune up kit and installing the parts. It is very simple and you do not need any "special" tools.
Old Apr 20, 2008 | 08:39 AM
JPN's Avatar
JPN
Do you still have the service receipt/report that tells you exactly what parts they replaced?
JPN
Old Apr 20, 2008 | 10:07 AM
Psaboic's Avatar
I would do in order....
1. Check the airbox thermostat
2. Check the tire pressure and set to about 35 psi all around (low tire pressure, even 3-4 pounds will cause quite a drop in fuel economy)
3. Check for fuel leaks
4. Do a full tune up (use OEM volvo plugs, and MANN filters) a good place for parts is fcpgroton.com, ipdusa.com, or autohausaz.com
5. Keep us posted.
Glenn
tonyt
Oct 14, 2011 06:36 PM
CurranH
Sep 16, 2009 09:37 AM
Stevo4
Aug 31, 2009 09:22 PM
mjl
Jan 7, 2009 04:41 PM
dcjcdc
Sep 14, 2008 05:07 PM
