95 850 turbo problems
#21
On the bottom right of the intake manifold you should see a gold tube with a sliding lock nut on it, you wouldve had to undo this to take off your manifold in the first place. and then there is 2 bolts that hold the egr valve to the intake manifold. my guess is that they are completely clogged. Your car does have egr right? or did they get rid of that in '95?
#23
#24
well the egr was plugged, i cleaned it all it put a new maf in. and it ran great when i first started it up, then it started running rough and barely idling again and started sucking oil in again... also wouldnt revv over 3k rpm. started smelling like eggs when i revved it for a bit, so cat maybe...? can you run without a cat on these cars.
could the overfilled oil pan be causing it to suck oil in still?
#25
Running without a cat would give you more power as well as a deeper and louder sound. I am about to be running catless as they are so power restrictive and love the sound....but in regards to your other problem I am not sure...try asking the guys on volvospeed
what makes you think its sucking in oil? Unplug the line going from the oil sep to the ptc(the thicker tube) and feel if oil is coming out of it while running.
#26
#29
#30
#31
#32
#33
#35
UPDATE:
Well i did and oil change to the proper level and it was almost 3 quarts overfilled, well its not burning oil any more, but now i took one of the plugs out on the exhaust and it seems to rev up to 5k no problem, but it is idling at 700k and running rich, but im sure the front o2 sensor is bad from all the oil burnt through it, how could i verify this?
#39
