96' 850 P0171 System Too Lean -
Old Aug 23, 2015 | 02:29 PM
Benjimang's Avatar
Default 96' 850 P0171 System Too Lean -
Have a CEL on and don't honestly know much about volvos and was hoping you can explain which hose this is. I have one that looks like it's by the intake manifold and it has a good 1" gash in it. Second picture shows a hose(?) by the MAF and looks like it leads somewhere, but I can't find it whatsoever.
Any help would be appreciated, thanks.
Attached Thumbnails 96' 850 P0171 System Too Lean --33.jpg   96' 850 P0171 System Too Lean --22.jpg
Old Aug 24, 2015 | 11:03 PM
trektech's Avatar
Check all of your intake hoses, pipes and clamps - replace, tighten as nessesary. When you have stopped your intake air leaks, your lean condition will disappear . The vacuum line in picture 2 goes to the boost control solenoid located below the distributor. It's about 2 inches long with a wires plug in one end and 3 vacuum lines in the other. It lets the computer control the turbo boost pressure.
Old Aug 27, 2015 | 11:10 PM
Benjimang's Avatar
I got the intercooler hose taken care of, but the 2nd line in the diagram is kicking me in the butt... where to the boost control solenoid does it go? I see the three vacuum lines that go out, but I can't for the life of me figure out where it goes.
Old Aug 28, 2015 | 10:47 AM
https://www.google.com/search?q=volv...Gw-DqIhS7-M%3D
found this pic set googling "volvo 850 boost control solenoid"
Old Aug 28, 2015 | 01:01 PM
Benjimang's Avatar
It looks like it goes beneath the distributor caps? I'm really lost right now because I keep getting conflicting answers, is there a chance there's a vacuum line just deep down in the engine that I need to fish for?
Old Aug 28, 2015 | 05:10 PM
yep, some of the vacuum lines are a pain to get at - some go down under the intake manifold to the PCV system and there is (are?) a line to the boost controller which is under some parts over on the #5 cyl side of the engine (as you noted - by the distributor) which may require some minor removals...
seanq73
Apr 17, 2020 06:03 PM
crimsonseraph
Aug 9, 2015 10:33 AM
1bluecove
Jan 7, 2011 07:43 AM
elchingon2002
Mar 11, 2008 10:41 AM
