'96 850 Turbo: Blower Motor Stuck on High
Old Dec 8, 2013 | 04:32 PM
mjg1664's Avatar
Default '96 850 Turbo: Blower Motor Stuck on High
The blower motor is running on high speed, nothing on the ECC panel is working or affecting the speed/on/off/fan direction/defrost. Fan does stop when car is off or fuse is pulled. Replaced the blower motor resistor (Intermotor RU1202) and no change. Motor still running on high speed. ECC panel has driver/passenger temp controls and an AUTO feature to the left of the Off position. Any other ideas would be greatly appreciated!
Old Dec 8, 2013 | 09:14 PM
Hi and welcome to the forum.
If you are sure you replaced the resistor with a good one, you may have a bad relay under the fuse panel. Swap the J relays there and see if anything changes.
Old Dec 9, 2013 | 11:48 AM
mjg1664's Avatar
Thanks for this. The part was purchased new from Advance Auto Parts, so I'm assuming it was working since the blower came right on when it was plugged in, but still won't do anything but run on 60 degree high air. I will do as you suggest next. Trying to avoid having to remove the ECC panel as I've heard this never turns out well.
Old Dec 9, 2013 | 12:04 PM
97black850's Avatar
the panel with the controls on it is easy, the MCC panels are a different story however
Old Dec 23, 2013 | 12:28 PM
mjg1664's Avatar
rspi/97black850;
mechanic is telling me that the J relays are fine - that it is the main switch at the ECC panel and that this part is $800 but could not provide a part#. I cannot figure out what the name of the part is to look it up myself - any ideas from the group would be apprecciated! Cannot do $800!
Old Dec 23, 2013 | 08:06 PM
I can get you a used unit but my bet is on the fan resistor. PM me if you'd like for me to get you a use unit which will have a warranty.
Old Dec 24, 2013 | 05:46 PM
mjg1664's Avatar
I did buy a second resistor - a big piece with several long metal pieces sticking out the back. Same thing. I found a climate control unit on Ebay for $65 today and went ahead and bought it. Saw some for over $900! Hopefully this fixes it. Getting close to giving up on this car - almost 18 years. Thanks for the help.
Old Dec 24, 2013 | 06:40 PM
Isn't it worth fixing ??
maccampbells
Jan 20, 2015 07:17 AM
Theo T
Jul 3, 2014 03:19 PM
3s0x
Mar 22, 2012 08:06 AM
jasenklems
Jul 24, 2011 06:25 PM
tn850
Dec 5, 2007 07:20 PM
