96 r ecu
if i were to be able to get my hands on a 96 R ECU and wanted to put that ECU in my 96 turbo, is that possible? wat can i expect to change? and would anything get affected by it? would i have to replace any certain amount of parts?
No, it's a direct swap. You technically get a 40 hp gain,which equals to about 1-2 more psi boost for a second or two. You would get more gains with a boost gauge and MBC, but more efficient gains with the ECU.
couldnt i just do all 3? ECU, MBC, and boost guage?
aswell wat r great MBC's but nothing to intensely expensive |
I have a 95 T-5R ECU for Sale
would that work fine on a 96 turbo? and how much?
It would work for a 96 but you will get a CEL for the EGR. Just do a google search for MBC. You could do all three, but it would be kind of pointless. The instead of 9-10 PSI on the stock ECU, the R ECU gives you 11-12 PSI, so there's really no reason in spending the money on a MBC for one more psi.
Originally Posted by gilber33
(Post 185584)
CEL/ EGR????? and oooo well if i can get both parts cheap then i'd be pretty happy |
You'll get a check engine light for the EGR because his ECU is from a 95 T5-R which had the EGR and your car is a 96 which did not have the EGR. So the ecu will work, but it will be looking for an EGR and not find one, hence the CEL. I would either get the ECU or the MBC, doesn't make sense to get them both. IMO the ecu would be a better buy because you'll be getting a little added HP and boost the proper way.
makes sense, wat does a used R ecu go for no adays, even if i hit some junkyards to find the ecu?
Good luck at jy. One, because they're aren't that many R's to begin with, and two, they're a hot item. Usually they go anywhere from 100-150.
Or.
Spend a good 700 on a IPD one. I can grab a used IPD one for 450 locally. I know a guy selling his. |
If you go that route, I would highly recommend a full stage zero and exhaust first.
S_moneh,
Do your homework and shoot me an offer. Its a good ECU from a running T-5R. |
alrity checked inventory at some local junkyards and it just so happens thers 3 96 R's at the scrapper( i know sad!) soooo now that i have found some candidates, how do i know which big block in the box is the ECU so i can go ahead and take one and slap it into mine? :)
Pretty sure it's the ones that say 7.2 on them. I think. Where are you located anyways?
not far from toronto, its in a toronto scrap yard, canada :)
Bosch = ECU
Asian Warner = Tranny module. |
I want a pick n pull so bad, I would go there every weekend to buy stuff.
Originally Posted by tech
(Post 186516)
Bosch = ECU
Asian Warner = Tranny module. always? perfect, thanks so much :) |
Unless it is a stick then it will only have the Bosch one.
